fixed
fluid
User Info
Latest:
DavinaCervante
New Today:
0
New Yesterday:
0
Overall:
17182
Online Now [420]:
Visitors:
420
Bots:
0
Members:
0
Today:
42736
Total:
142425562
Main Menu
General
News
Surveys
Forums
Info Goodies
Links
Member Map
Order a Site Sticker
Search
Search Forums
Web Stats
Statistics
Top 10
Members
206Info Meet Map
206 Info Calendar
My Account
Trade Rating
Site Introduction
Forums › Request a how-to › Post a reply › Re: Remove Steering Wheel - Multiplexed
Forums Home
Forum FAQ
Search
Forum Index
Request a how-to
Username
Subject
Message body
Emoticons
More smilies
Default
Dark Red
Red
Orange
Brown
Yellow
Green
Olive
Cyan
Blue
Dark Blue
Indigo
Violet
White
Black
Tiny
Small
Normal
Large
Huge
[quote="NathanG"][quote="Brian"]you need to take the airbag out first, which is held by 2 clips that you need to push in towards the middle (if i remember right) of the steering wheel. So you'll need a something thin to push it, ie a small screw driver. Then the middle bolt is a T55 Torx bit. then you need to remove the cowling and then you'll get to the COM2000. Just be careful when you remove the airbag as there's wires attached to it that are linked with the COM2000 unit.[/quote] Also, and this is a bit of a DO NOT FORGET, disconnect the battery is by following the proper procedure. I changed my comms 2000 at the week end, had to by a brand new one. Entire job takes about 10-15 mins. Use a flat blade screw driver. Park with wheels straight disconnect battery in the proper manner (see how to section) Remove cowlin Under the steering wheel theres a small hole with a metal bit inside tha runs across it, put that metal bit in with a screw driver anf air bag should pop out. Remove airbag taking care of 3 wires, 1 either side of airbag, 1 on a spade connector on the rear. The rest is straight forward.[/quote]
Options
HTML is
ON
BBCode
is
ON
Smilies are
ON
Disable HTML in this post
Disable BBCode in this post
Disable Smilies in this post
Topic review
GNU GPL
Code Credits
Privacy Policy
