fixed
fluid
User Info
Latest:
Prebs91
New Today:
0
New Yesterday:
0
Overall:
17187
Online Now [560]:
Visitors:
560
Bots:
0
Members:
0
Today:
172919
Total:
154188329
Main Menu
General
News
Surveys
Forums
Info Goodies
Links
Member Map
Order a Site Sticker
Search
Search Forums
Web Stats
Statistics
Top 10
Members
206Info Meet Map
206 Info Calendar
My Account
Trade Rating
Site Introduction
Forums › Request a how-to › Post a reply › Re: How to req: Trs tow strap
Forums Home
Forum FAQ
Search
Forum Index
Request a how-to
Username
Subject
Message body
Emoticons
More smilies
Default
Dark Red
Red
Orange
Brown
Yellow
Green
Olive
Cyan
Blue
Dark Blue
Indigo
Violet
White
Black
Tiny
Small
Normal
Large
Huge
[quote="drunknmunky"][quote="Uz"]I've looked at it and you need to cut as much of the 'hook' part of it off then drill a hole into the centre of the remain and then bolt and nut with two washers above and below to fit it to that length. I'll be getting mine fitted at the bodyshop next month front and rear as the cut area needs to be sprayed back up again one it's been cut.[/quote] surely instead of cutting as much off as possible you can take the bumper off and cut right back to where it is welded onto the car then you attach your tow strap to that point which will be the chassis? its safer that way and you can then bolt it right through aswell :? and what will need re-sprayed nothing should need resprayed as you wont affect any paintwork if you taker the buympers off and cut right back iv looked thoroughly at this as i have had my tow straps for a while and im pretty sure you could do it yourself and theres nothing needing resprayed[/quote]
Options
HTML is
ON
BBCode
is
ON
Smilies are
ON
Disable HTML in this post
Disable BBCode in this post
Disable Smilies in this post
Topic review
GNU GPL
Code Credits
Privacy Policy
