fixed
fluid
User Info
Latest:
DavinaCervante
New Today:
0
New Yesterday:
0
Overall:
17182
Online Now [197]:
Visitors:
196
Bots:
1
Members:
0
Today:
30936
Total:
143157423
Main Menu
General
News
Surveys
Forums
Info Goodies
Links
Member Map
Order a Site Sticker
Search
Search Forums
Web Stats
Statistics
Top 10
Members
206Info Meet Map
206 Info Calendar
My Account
Trade Rating
Site Introduction
Forums › Request a how-to › Post a reply › Re: How to remove rear door cards?
Forums Home
Forum FAQ
Search
Forum Index
Request a how-to
Username
Subject
Message body
Emoticons
More smilies
Default
Dark Red
Red
Orange
Brown
Yellow
Green
Olive
Cyan
Blue
Dark Blue
Indigo
Violet
White
Black
Tiny
Small
Normal
Large
Huge
[quote="Harry"]Firstly have to remove the front seat bellts. Pop the cover off where it slides along the rail at the bottom and undo the bolt then looses the strap off the rail. Pull off the cover that you pull to move the seatbelt up and down (seriously just pull it off it will come). Undo the small torx bit under the cover and take off the other plastic part that loosens. Undo the nut so the seatbelt falls off this part. Then you have to remove the passenger seatbelt but first go into the boot and locate two small torx bolts on the C pillars (near the interior light on the passenger side) which will enable you to remove the whole C pillar. Go into the passenger seats and see where the seatbelt is attached at the bottom, remove it. Pull the B pillar off where you undid the front seatbelt. I would advise taking the rear seat benches out (not the back panel) will make it a lot easier. At this point the rear door cars should have nothing else obstructing it's way to come out so just pull it and pop it out. Then obviously to re attach it's the same in reverse.[/quote]
Options
HTML is
ON
BBCode
is
ON
Smilies are
ON
Disable HTML in this post
Disable BBCode in this post
Disable Smilies in this post
Topic review
GNU GPL
Code Credits
Privacy Policy
