fixed
fluid
User Info
Latest:
eionpeu
New Today:
0
New Yesterday:
0
Overall:
17120
Online Now [52]:
Visitors:
51
Bots:
1
Members:
0
Today:
1045
Total:
97265232
Main Menu
General
News
Surveys
Forums
Info Goodies
Links
Member Map
Order a Site Sticker
Search
Search Forums
Web Stats
Statistics
Top 10
Members
206Info Meet Map
206 Info Calendar
My Account
Trade Rating
Site Introduction
Forums › Request a how-to › Post a reply › Re: replace door locks and ignition barrell with pics
Forums Home
Forum FAQ
Search
Forum Index
Request a how-to
Username
Subject
Message body
Emoticons
More smilies
Default
Dark Red
Red
Orange
Brown
Yellow
Green
Olive
Cyan
Blue
Dark Blue
Indigo
Violet
White
Black
Tiny
Small
Normal
Large
Huge
[quote="MrBSI"][quote="Harry"]You will really struggle with getting the door ones off without removing the doorcards I doubt it's possible as they need to be undone and reconnected to the solenoids inside. [/quote] [quote="smiddies"] You will need to take the doorcard off to gain access to behind the door lock, basically its got a metal holder, get a flat head and a hammer, and basically place the flat head into the corner of the metal holder, and hit with hammer, and then just switch the door lock over, ensuring the plastic bit on the door lock is back into position! [/quote] Do either of you 2 actually know what your talking about? :roll: Door lock barrels on a 206 & most other PSA Peugeot / Citroen stuff, p**s easy job, less then 90 seconds a side, no need to remove the door card, Peugeot designed in an easy way of removing the lock barrel securing clip. Remove rubber bung. Insert your threaded tool & screw it in to the clip. Push the tool in to the door to release the clip. Lift the barrel out & unclip it. Refitting is reversal of removal. Ignition barrel - about 5 minutes: Remove the plastic trim around the steering lock. Unplug the barrel from the wiring loom. Check for a small securing grub screw in end of barrel ( not all barrels have this! ) Insert key & turn to the LOCK SERVICE position. Push the securing clip down & then pull the barrel out the steering lock, if the transponder aerial gets in the way unplug / unclip it. Refitting is reversal of removal.[/quote]
Options
HTML is
ON
BBCode
is
ON
Smilies are
ON
Disable HTML in this post
Disable BBCode in this post
Disable Smilies in this post
Topic review
GNU GPL
Code Credits
Privacy Policy
