fixed
fluid
User Info
Latest:
heikkisj
New Today:
0
New Yesterday:
1
Overall:
17126
Online Now [66]:
Visitors:
65
Bots:
1
Members:
0
Today:
6154
Total:
100184838
Main Menu
General
News
Surveys
Forums
Info Goodies
Links
Member Map
Order a Site Sticker
Search
Search Forums
Web Stats
Statistics
Top 10
Members
206Info Meet Map
206 Info Calendar
My Account
Trade Rating
Site Introduction
Forums › Request a how-to › Post a reply › Re: 1.4 hdi injector seals
Forums Home
Forum FAQ
Search
Forum Index
Request a how-to
Username
Subject
Message body
Emoticons
More smilies
Default
Dark Red
Red
Orange
Brown
Yellow
Green
Olive
Cyan
Blue
Dark Blue
Indigo
Violet
White
Black
Tiny
Small
Normal
Large
Huge
[quote="richpowell91"]Its quite a job, ive done the bottom copper injector seals and the leak of pipe seals twice now on customers cars. Basically to get at the injectors the rocker cover/intake manifold, air intake and upper cambelt cover has got to be removed. Im sure its all covered in a haynes manual though so that might be a better idea than finding out while you do it. Whilst your doing it seeing as your striping it down i would recommend replacing the leak of pipe seals and check the pipes conditions. Also check the injector pipe harness (check service box for picture, its the set of fuel pipes that include the hand primer and run from the fuel filter under the air box to the fuel pump.) As there prone to having the air box rubbing/chafing on the pipes causing a small hole which allows air into the system and means you have to hand prime it to get all the air out the system in order to start the car.[/quote]
Options
HTML is
ON
BBCode
is
ON
Smilies are
ON
Disable HTML in this post
Disable BBCode in this post
Disable Smilies in this post
Topic review
GNU GPL
Code Credits
Privacy Policy
