fixed
fluid
User Info
Latest:
Prebs91
New Today:
0
New Yesterday:
0
Overall:
17187
Online Now [765]:
Visitors:
764
Bots:
1
Members:
0
Today:
153808
Total:
150226446
Main Menu
General
News
Surveys
Forums
Info Goodies
Links
Member Map
Order a Site Sticker
Search
Search Forums
Web Stats
Statistics
Top 10
Members
206Info Meet Map
206 Info Calendar
My Account
Trade Rating
Site Introduction
Forums › Request a how-to › Post a reply › Re: HOw to remove a complete Dashboard ?
Forums Home
Forum FAQ
Search
Forum Index
Request a how-to
Username
Subject
Message body
Emoticons
More smilies
Default
Dark Red
Red
Orange
Brown
Yellow
Green
Olive
Cyan
Blue
Dark Blue
Indigo
Violet
White
Black
Tiny
Small
Normal
Large
Huge
[quote="Steve180"]1. Removing Disconnect the battery. Figure : c5ff0dkc Remove : The steering wheel module (1) (Refer to the procedure Check - Repair operations - Adjustment : Airbags) The steering wheel (2) marking its position on the splines The centre console (3) The lower trim (4) under the steering wheel The side switches (5) (According to equipment) The blanks (6) The steering column (/) Pull the lower section of the visor (7) to detach it. Finish unclipping the upper section. Remove the binnacle ( 7). Remove the fastener on rear of dial unit Disconnect the instrument panel connectors . Remove the instrument panel Unclip the upper centre panel by pulling it towards you. Disconnect the hazard warning lights switch Remove the mountings at the bottom of the display module Disconnect the connector on rear/ lower Remove the clock or the display (According to equipment) . Remove the panel or the radio (According to equipment) . Remove the mountings at the top of the fascia panel Unclip the centre panel, by pulling it gently towards you. Remove the centre panel. Remove the mountings from the heater blower(s)/ top section and a/c or heater controls Remove the fastener between dashboard and floor console (gearstick sits in floor console) Remove the ashtray/ cup holder (depending on equipment) Remove the fixing for the earth wires. Remove end panels on the dash (near the doors) Remove the mountings inside Disconnect the connector on internal wire Remove the fastener lug (there may be two of these on later models... can be found either near scuttle panel or underneath near the sterring column, should be white/ black, about 1/4 inch long) On each side, lift the fascia and pull it towards you to detach it from the air conditioner and the windscreen.[/quote]
Options
HTML is
ON
BBCode
is
ON
Smilies are
ON
Disable HTML in this post
Disable BBCode in this post
Disable Smilies in this post
Topic review
GNU GPL
Code Credits
Privacy Policy
