fixed
fluid
User Info
Latest:
Prebs91
New Today:
0
New Yesterday:
0
Overall:
17187
Online Now [865]:
Visitors:
864
Bots:
1
Members:
0
Today:
12515
Total:
150328585
Main Menu
General
News
Surveys
Forums
Info Goodies
Links
Member Map
Order a Site Sticker
Search
Search Forums
Web Stats
Statistics
Top 10
Members
206Info Meet Map
206 Info Calendar
My Account
Trade Rating
Site Introduction
Forums › Request a how-to › Post a reply › Re: how do I remove the outer black plastic door trim?
Forums Home
Forum FAQ
Search
Forum Index
Request a how-to
Username
Subject
Message body
Emoticons
More smilies
Default
Dark Red
Red
Orange
Brown
Yellow
Green
Olive
Cyan
Blue
Dark Blue
Indigo
Violet
White
Black
Tiny
Small
Normal
Large
Huge
[quote="P6RAF"]Here's my experience... Firstly push/slide the trim as far back towards the opening end as it will go then lift the trim away from the body work at the door opening end. BUT make sure you lift/pull the trim at least an inch away from the panel then using your palm nudge the whole trim towards the front of the door. Most clips will then slide out of the back of the trim staying in the door. Maybe the ones closest the lifted end will break so make sure you have a few spare ready. However, if you do as I did :cry: and only lift the trim a centimeter or so away then nudge it forward it breaks/cracks the molded tab from the trim. [IMG]http://i1273.photobucket.com/albums/y408/Perry_Graf/20130118_1635021_zpsaec8e530.jpg~original[/IMG] Then you're left with a gluing job to try to strengthen the tab so that when refitted it sits flush to the body work. Get this wrong and it doesn't ever sit tightly to the body work and looks terrible. The remaining clips left in the door can be removed without breaking them if you are careful. I found if you turn the clips so they are an angle, like a diamond, then using some, flat, stiff plastic like a ruler you can push in the coned end from a 3 O'clock position in enough to enable the clip to be pulled/wiggled out. [IMG]http://i1273.photobucket.com/albums/y408/Perry_Graf/clips_zpse31454ca.jpg~original[/IMG] [IMG]http://i1273.photobucket.com/albums/y408/Perry_Graf/20130119_1005061_zps55a9a2bb.jpg~original[/IMG] Good luck[/quote]
Options
HTML is
ON
BBCode
is
ON
Smilies are
ON
Disable HTML in this post
Disable BBCode in this post
Disable Smilies in this post
Topic review
GNU GPL
Code Credits
Privacy Policy
