fixed
fluid
User Info
Latest:
Kifi69
New Today:
0
New Yesterday:
0
Overall:
17183
Online Now [273]:
Visitors:
272
Bots:
1
Members:
0
Today:
27560
Total:
144848221
Main Menu
General
News
Surveys
Forums
Info Goodies
Links
Member Map
Order a Site Sticker
Search
Search Forums
Web Stats
Statistics
Top 10
Members
206Info Meet Map
206 Info Calendar
My Account
Trade Rating
Site Introduction
Forums › Request a how-to › Post a reply › Re: Remove door pins
Forums Home
Forum FAQ
Search
Forum Index
Request a how-to
Username
Subject
Message body
Emoticons
More smilies
Default
Dark Red
Red
Orange
Brown
Yellow
Green
Olive
Cyan
Blue
Dark Blue
Indigo
Violet
White
Black
Tiny
Small
Normal
Large
Huge
[quote="mtempsch"][quote="namrood"]Hi I have a pair of irmscher door pins which I had kept when I had an astra coupe. The paperwork said it will fit vauxhall's and peugeot's. How do I remove the door pin that's shows the door is locked or unlocked. On the astra it was a matter of popping off a red covers and the pin would come off? Do I need to remove the door card on the 206? Thanks[/quote] IIRC, the pins on the 206 are moulded onto the steel rod that goes to the lock mechanism. Depending on the length of your new pins you might be able to simply cut the steel rod just below the existing pin. If not, you'll have to remove the plastics of the pin from the rod... Wire cutting pliers, dremel, etc For either I think you'll need to remove the cards for proper access. Unless someone knows some trick for the pins?[/quote]
Options
HTML is
ON
BBCode
is
ON
Smilies are
ON
Disable HTML in this post
Disable BBCode in this post
Disable Smilies in this post
Topic review
GNU GPL
Code Credits
Privacy Policy
