Author |
Sezticle |
Posted: Mon Dec 20, 2010 1:37 pm Post subject: Re: Fitting a spoiler |
JordGJ wrote: |
searchhhhhhh |
Jord your so helpfull!! |
Jayyy1989 |
Posted: Fri Dec 10, 2010 10:22 am Post subject: Re: Fitting a spoiler |
I used Tigerseal and i was very dubious, however it is actually brilliant stuff!!! Spoiler is solid as a rock and as mentioned by someone else earlier you can lift the back of the car up with the spoiler its that strong.
Just make sure you key both surfaces, roughly sand the spoiler where it meets the car and use masking tape to secure while the tigerseal cures.
Tigerseal = A++++++++ |
Mrs_Howey |
Posted: Fri Dec 10, 2010 7:41 am Post subject: Re: Fitting a spoiler |
My first spoiler was bolted on, never came off, although i did have rust underneath were the spoiler had been and water was sitting under it,
My second spoiler if glued on, which was done at the leeds meet earlier this year and it's fine, not moved at all
So both ways work, just it's easier to glue i'd say, as i wouldn't want to drill into my body work |
MrBSI |
Posted: Fri Dec 10, 2010 7:19 am Post subject: Re: Fitting a spoiler |
-RAJ- |
Posted: Fri Dec 10, 2010 6:22 am Post subject: Re: Fitting a spoiler |
i just bolted mine, been on for 3yrs now no problems |
Kersh |
Posted: Fri Dec 10, 2010 6:15 am Post subject: Re: Fitting a spoiler |
mines just glued on with tiger seal, works a treat..
its survived a 7 hour drive at over 80mph on a hot day so it passes the test for me.. been on for months now
i found drilling half holes in the bit on the spoiler where it glues to the car (like 2-3mm deep) works perfectly at giving a rough bonding surface.. that combined with keying the car paint and jobs a good'un |
Danw_VVT |
Posted: Fri Dec 10, 2010 5:43 am Post subject: Re: Fitting a spoiler |
im doing mine this weekend. but using metal to metal adhesive ( stuff they use in body shops to fix panels together)
it what ive used on the golfs corsas etc and never failed me
puggy time on sunday! |
roberto.f |
Baz206 |
Posted: Fri Dec 10, 2010 4:57 am Post subject: Re: Fitting a spoiler |
I just bonded mine on , about 4 months ago,
used sika flex no sign of it moving at all !!
Been through carwash a few times with it aswell !!! |
SAB206 |
Posted: Thu Dec 09, 2010 7:44 pm Post subject: Re: Fitting a spoiler |
I personally wouldn't recommend just relying on a PU sealant like tiger seal.
Can't beat gold old Screws with tiger seal for extra protection.
It's not you that crashes when it falls off, it's the person behind... not worth it |
Andrew |
Posted: Mon Nov 22, 2010 8:12 am Post subject: Re: Fitting a spoiler |
Peugeot dealership did mine too.. bolted and bonded in my case. £218 to buy it, have it sprayed and fitted. A lot of labour going in on their part so I thought it was fair |
liltoads206 |
Posted: Mon Nov 22, 2010 8:04 am Post subject: Re: Fitting a spoiler |
yeh thought you might say tiger seal but is it really that good? would it really stay on if im doing 70etc lol down the motorway? |
juanfernandes |
Posted: Mon Nov 22, 2010 5:42 am Post subject: Re: Fitting a spoiler |
S222Chan wrote: |
i had peugeot fit mine, and it was bonded on... |
How much did they charge for this? |
Lee. |
Posted: Sun Nov 21, 2010 7:54 pm Post subject: Re: Fitting a spoiler |
Tigerseal and stick it on, did my old car with it and you could pick the back end of the car up with it when it had gone off! |
Jammo |
