| Author |
| 206ACE |
Posted: Fri Dec 31, 2010 7:32 am Post subject: Re: Colour coding bump strips |
thanks for all your help will start that soon and post pics c
cheers |
| PUG91 |
Posted: Thu Dec 30, 2010 1:34 pm Post subject: Re: Colour coding bump strips |
| Ste206 wrote: |
| PUG91 wrote: |
And the actual painting the only real tips are too make sure you have more than enough primer, colour and lacquer.
Get a whole bunch of different grade sand paper, and just take everything really slowly, don't skip parts or rush in between coats prep makes perfect  |
206info.co.uk/Forums/v...14410.html  |
amazing job mate!!!! |
| Ste |
Posted: Thu Dec 30, 2010 1:32 pm Post subject: Re: Colour coding bump strips |
| PUG91 wrote: |
| Bailey |
Posted: Thu Dec 30, 2010 1:31 pm Post subject: Re: Colour coding bump strips |
Rear torx is here
| PUG91 |
Posted: Thu Dec 30, 2010 1:27 pm Post subject: Re: Colour coding bump strips |
| PUG91 |
| JDave |
Posted: Thu Dec 30, 2010 1:23 pm Post subject: Re: Colour coding bump strips |
| If you get stuck at all there is alot of threads been made to help people in a similiar situation! |
| Luke |
Posted: Thu Dec 30, 2010 1:20 pm Post subject: Re: Colour coding bump strips |
| Ste206 wrote: |
And for the rear I have absolutly no idea
Three large torx screw located in the boot lip IIRC, then just unclips either side. |
| JordGJ |
Posted: Thu Dec 30, 2010 1:19 pm Post subject: Re: Colour coding bump strips |
| Mike wrote: |
| JordGJ wrote: |
| Don't colour code the mirrors do them gloss black, looks odd all white |
Or just white the caps? Gloss black base and housing with white caps? Maybe? |
Yer that wud work, but when the whole things white it looks a bit tacky, too much white! |
| Mike |
Posted: Thu Dec 30, 2010 1:17 pm Post subject: Re: Colour coding bump strips |
| JordGJ wrote: |
| Ste |
Posted: Thu Dec 30, 2010 1:15 pm Post subject: Re: Colour coding bump strips |
To answer the question though,
The side strips are held on with pop clips, so you just pop them off ( you'll probably break the clips in the process as there pretty brittle - so get some new ones ready )
I think the front bumper mould is held on with clips that slide into the bumper, not sure if theres also a bolt of two on that one, someone will let you know..
The wing mirrors are held in with 3 torx screws behind the plastic cover on the door inslide the car  |
| Ste |
Posted: Thu Dec 30, 2010 1:12 pm Post subject: Re: Colour coding bump strips |
| JordGJ wrote: |
^ Wise words  |
| JordGJ |
Posted: Thu Dec 30, 2010 1:09 pm Post subject: Re: Colour coding bump strips |
| 206ACE |
Posted: Thu Dec 30, 2010 1:08 pm Post subject: Colour coding bump strips |
hi there i am going to take off the side door stips, bumper bits and colour code them, how do they come off?? and wing mirrors
also any hints/tips would be greatly appreciated
many thanks
