| Author |
| Panda |
Posted: Sat Feb 26, 2011 1:13 pm Post subject: Re: How to remove and replace the steering wheel |
| Thanks to all of you for your help, I am sure that I will have no problem now. |
| Mrs_Howey |
Posted: Sat Feb 26, 2011 11:56 am Post subject: Re: How to remove and replace the steering wheel |
| MrBSI wrote: |
| usher wrote: |
| DIdnt think about that is there much difference in how to remove |
Multiplexed airbag is clipped on so you aint gonna find the 2 torx screws to undo
You also aint gonna find an orange conector plug behind a multiplexed airbag, you will find a blue & also a green plug both with yellow securing clips. |
So it just pulls off then
Might change mine this week then |
| MrBSI |
Posted: Sat Feb 26, 2011 5:48 am Post subject: Re: How to remove and replace the steering wheel |
| usher wrote: |
| Lee |
Posted: Sat Feb 26, 2011 5:13 am Post subject: Re: How to remove and replace the steering wheel |
Clips  |
| Mrs_Howey |
Posted: Sat Feb 26, 2011 4:58 am Post subject: Re: How to remove and replace the steering wheel |
| MrBSI wrote: |
| usher wrote: |
| QUite an easy one.2 torx behind the wheel hloding on the airbag. Then the airbag will come out disconect the orange connector . |
& if the car is MULTIPLEXED then those instructions aint going to work  |
How does the multiplexed one come off?
| Lee |
Posted: Sat Feb 26, 2011 4:42 am Post subject: Re: How to remove and replace the steering wheel |
Technically it shouldn't deploy if the keys aren't in, and by the time you've taken the shrouding off the power should have gone away from the airbag.
But its better to be safe than sorry. |
| usher |
Posted: Sat Feb 26, 2011 4:24 am Post subject: Re: How to remove and replace the steering wheel |
| MrBSI |
Posted: Sat Feb 26, 2011 4:13 am Post subject: Re: How to remove and replace the steering wheel |
| usher wrote: |
| usher |
Posted: Sat Feb 26, 2011 3:59 am Post subject: Re: How to remove and replace the steering wheel |
| LOl ive been lucky first time I did mine I didnt disconnect the batt at all |
| ma.langan |
Posted: Sat Feb 26, 2011 3:30 am Post subject: Re: How to remove and replace the steering wheel |
when disconnecting the battery its better to leave it for more than ten mins just to make sure thers no wafer of a current in the cars circuits, ya dont want an airbag in ya face lol, also make sure your steering wheel is ded centre, mark it against the ignition column first (wer key goes) so ya dont end up with it on an angle  |
| usher |
Posted: Sat Feb 26, 2011 3:18 am Post subject: Re: How to remove and replace the steering wheel |
QUite an easy one.2 torx behind the wheel hloding on the airbag. Then the airbag will come out disconect the orange connector . Then a big torx bolt on the midle after you have removed that pull hit wiggle the wheel it is tough but will come in the end.
Before starting disconect the batt. Wait 10 mins and make sure the wheel is straight
Cant do pics as I on my mob |
| Panda |
Posted: Sat Feb 26, 2011 2:53 am Post subject: How to remove and replace the steering wheel |
| How do you remove and replace the steering wheel? |
