| Author |
| MrBSI |
Posted: Mon Mar 14, 2011 6:36 pm Post subject: Re: Changing steering wheel. |
As long as you get the correct BOLT on type / non plexed steering wheel its a piece of cake
Disconnect the battery for 5 minutes.
Airbag is held in with 2 screws from behind the steering wheel spokes.
One orange plug to undo & one push on wire terminal.
One wire screwed on to wheel.
DO NOT use the steering lock to hold the steering wheel while you crack the bolt!
Loosen a few turns BUT DO NOT REMOVE the torx bolt ( think its a 50 or 55 )
Smack the wheel firmily from behind using both hands
When the wheel pops free of the splines then remove the bolt.
Thats it basically. |
| nakednakeddave |
Posted: Mon Mar 14, 2011 6:32 pm Post subject: Re: Changing steering wheel. |
eaaasy
all you need is a torx set and a ratchet....
take the torx bolts out the back holding th airbag in...and then unplug and remove
then undo the big torx in the middle when the airbags removed..
then pull of, then reverse to fit new wheel..... |
| devildriverxii |
Posted: Mon Mar 14, 2011 6:30 pm Post subject: Changing steering wheel. |
I'm going to have to do this pretty soon.
Is it easy, or is a professional recommended?
I had a look through the how to's but I couldn't see anything.
Cheers
Edit: I'm really sorry...I obviously couldn't see 8 posts down  |
