| Author |
| Timon2210 |
Posted: Sat Apr 09, 2011 12:02 pm Post subject: Re: how can i change my antenna base? |
| pug206lx wrote: |
Front mounted aerial?
Pop the light out with a screwdriver by prising it out on the end that doesn't have any switches, unplug the light
Remove the plastic surround by removing the screws and take this out
Remove the metal cover from the aerial underside and then remove the bolt. The aerial will come off from outside.
Monitor the area for a while after doing this because once disturbed they tend to leak. I've found that silicone sealant fixes this. |
,but I don't think it needs silicone sealant,because he says that he bought a new one,but if he means a new one (used),then he should monitor it as you said  |
| MrBSI |
Posted: Sat Apr 09, 2011 11:23 am Post subject: Re: how can i change my antenna base? |
| pug206lx wrote: |
Aerial base should really always be siliconed sealed for added piece of mind.
PSA Peugeot / Citroen have suffered leaking roof aerial seals for 20+ years that I know of  |
| pug206lx |
Posted: Sat Apr 09, 2011 11:14 am Post subject: Re: how can i change my antenna base? |
| ali_jariani |
Posted: Sat Apr 09, 2011 11:07 am Post subject: how can i change my antenna base? |
| i've broken my antenna base ! i bought a new one but i don't know how to change it ! i think i should remove interior light area! but i couldn't! |
