| Author |
| Defjester |
Posted: Wed Jul 06, 2011 1:50 pm Post subject: Re: Removing Front seat |
| Lee wrote: |
Ratchet with a extension bar does the trick  |
I used the A-Team method and improvised  |
| Lee |
Posted: Wed Jul 06, 2011 1:47 pm Post subject: Re: Removing Front seat |
| Defjester |
Posted: Wed Jul 06, 2011 1:41 pm Post subject: Re: Removing Front seat |
| sicskate wrote: |
| Any clues how to get to the bolts on the front of the front seats?? |
The one's nearest the gear stick?
I used a T40 Key (allen key L shape) with a pair of mole grips locked in at the top for extra purchase.
Gently pull the bolster towards you for extra room so you've got an almost vertical drop to the bolt and then undo the bolt. |
| sicskate |
Posted: Wed Jul 06, 2011 7:47 am Post subject: Re: Removing Front seat |
| j4m1e |
Posted: Tue May 17, 2011 4:26 am Post subject: Re: Removing Front seat |
| ok cheers for the heads up lol |
| BigGreenDave |
Posted: Tue May 17, 2011 4:18 am Post subject: Re: Removing Front seat |
| Lol well you may need afew hours to find the bolts haha and get the right tool and then to get them out without constantly smacking yourself haha. Just make sure when you take them out you have hold of the bottom maybe put towels around the rails they are sharp edged an will hurt your paint |
| j4m1e |
Posted: Tue May 17, 2011 3:41 am Post subject: Re: Removing Front seat |
ok ..... i take it i may need a few hours to be on the safe side  |
| DeadEyePaul |
Posted: Tue May 17, 2011 3:38 am Post subject: Re: Removing Front seat |
| Once you have undone the bolts I found the easiest way of removing your old seats is to drag them through the car and out the boot. Just adjust the back rest so it folds inwards |
| j4m1e |
Posted: Tue May 17, 2011 3:31 am Post subject: Re: Removing Front seat |
excellent thank you for your help  |
| iainlovatt |
Posted: Tue May 17, 2011 3:19 am Post subject: Re: Removing Front seat |
| j4m1e wrote: |
ok cheers i just wanted to check if they would be a problem in the MOT and i take it the bolts are in the rails under the seat  |
correct! torx t40 i think! |
| j4m1e |
Posted: Tue May 17, 2011 3:18 am Post subject: Re: Removing Front seat |
| BigGreenDave |
Posted: Tue May 17, 2011 3:16 am Post subject: Re: Removing Front seat |
Easy to take out but you have to
Make sure your buckets will fit with the right rails and MOT will pass it as long as there secure and don't rattle and have seat belts/harnesses.
Seats are your life not just style :.P as my MOT guy once said |
| j4m1e |
Posted: Tue May 17, 2011 3:15 am Post subject: Re: Removing Front seat |
nope no airbags its a X reg  |
| iainlovatt |
Posted: Tue May 17, 2011 3:14 am Post subject: Re: Removing Front seat |
| 4 bolts hold a seat in, do you have airbags in the seat? |
| j4m1e |
Posted: Tue May 17, 2011 3:09 am Post subject: Removing Front seat |
hi guys ive had a bargin offered to me (two bucket seats for £100) of a mate and i was wondering how easy is it to remove the seats and replace them with the new bucket seat ?
and will it effect the MOT/Service having the bucket seats ?
Cheers in advance |
