| Author |
| rudymason |
Posted: Mon May 23, 2011 3:45 pm Post subject: Re: remove multiplexed steering wheel and others |
found it! sorry bout all the fuss, just i dont wanna buy a sports fron bumper and find its a harder job that i anticipated !!
Cheers for all the help  |
| MrBSI |
Posted: Sat May 21, 2011 7:35 am Post subject: Re: remove multiplexed steering wheel and others |
| rudymason wrote: |
| where is that located :S cus ive been to my car n cant see a foglamp errm logo or anything? |
The twisty thing in the middle of the headlamp stalk
The one right on the end does the headlights.
The other one just a bit further in is for the foglights. |
| rudymason |
Posted: Sat May 21, 2011 7:33 am Post subject: Re: remove multiplexed steering wheel and others |
| MrBSI |
Posted: Sat May 21, 2011 4:06 am Post subject: Re: remove multiplexed steering wheel and others |
| rudymason wrote: |
| so then the stalk would be useless? as on mine it has sides first then full beam and thats it?? |
You use the ORIGINAL fog lamp switch thats already fitted to your stalk. |
| MrBSI |
Posted: Sat May 21, 2011 4:04 am Post subject: Re: remove multiplexed steering wheel and others |
| DanPug206 wrote: |
Not yet will do soon tho
Currently have yellow old crappy ones |
Get the GTI headlamp stalk if your planning on going twin H7 crystal in the future  |
| rudymason |
Posted: Sat May 21, 2011 3:52 am Post subject: Re: remove multiplexed steering wheel and others |
| DanPug206 |
Posted: Sat May 21, 2011 3:51 am Post subject: Re: remove multiplexed steering wheel and others |
| MrBSI |
Posted: Sat May 21, 2011 3:41 am Post subject: Re: remove multiplexed steering wheel and others |
| DanPug206 wrote: |
Will do mate, could I get the wiring of a car that's being broke, the car in question is a v reg GTi
Cheers |
You could do.
You got crystal headlights? |
| MrBSI |
Posted: Sat May 21, 2011 3:40 am Post subject: Re: remove multiplexed steering wheel and others |
| rudymason wrote: |
so my fogs would come on with my sidelights?? dont want to sound stupid but just making sure lol!!
cheers |
No
Your front fogs would only come on when you twist the foglamp switch.
You do need sidelights or dipped beam on first before you can activate the fog lights. |
| DanPug206 |
Posted: Sat May 21, 2011 3:36 am Post subject: Re: remove multiplexed steering wheel and others |
Cheers |
| rudymason |
Posted: Sat May 21, 2011 3:33 am Post subject: Re: remove multiplexed steering wheel and others |
cheers |
| MrBSI |
Posted: Sat May 21, 2011 3:32 am Post subject: Re: remove multiplexed steering wheel and others |
| DanPug206 wrote: |
Probs won't work on mine then
Old 1999 1.4 lx
That's that put the picture then
I'm sure there's a guide on wiring them
I'll search closer to the time
Still being prepared for painting ATM
Cheers tho |
Keep your eye on Ebay, the genuine Peugeot front fog light kits turn up from time to time.
Front fogs are easy to wire in.
Its if you want to use the original stalk switch that it gets a bit harder. |
| DanPug206 |
Posted: Sat May 21, 2011 3:22 am Post subject: Re: remove multiplexed steering wheel and others |
Old 1999 1.4 lx
Cheers tho |
| MrBSI |
Posted: Sat May 21, 2011 3:12 am Post subject: Re: remove multiplexed steering wheel and others |
| rudymason wrote: |
| ow do i go around sorting the bsi adjustment and when would the lights come as far as the stalk is concerned?? |
You need Peugeot Planet software to tweak the BSI unit.
Lee on here had Planet, only issue is he is far away from you.
As for the fogs.
First twist on the stalk switch would activate the fronts, a second twist would then activate the rear.
The stalk is just a switch, all it does is send a digital signal to the BSI unit which is the cars computer brain in overall charge of the electrical systems.
The BSI unit will then turn on the fog lights as requested. |
| rudymason |
Posted: Sat May 21, 2011 3:09 am Post subject: Re: remove multiplexed steering wheel and others |
