| Author |
| karimali831 |
Posted: Sat May 28, 2011 11:10 am Post subject: Re: Removing door cards?! |
Ahh thanks very muchs all  |
| Mikey2uk |
| Lee |
Posted: Sat May 28, 2011 11:07 am Post subject: Re: Removing door cards?! |
About 9 clips, three torx screws [handle, hinge side, one behind tweeter cover].
If it takes you longer than one minute, you're a retard  |
| Mikey2uk |
Again moved to the correction section and yet a again a search would of found the answer
www.206info.co.uk/Foru.../t=30.html |
| Seabook |
| undo 3 torx screw, remove the door handle (one screw), pull out the door opening catch and then pull out the door card |
| karimali831 |
Posted: Sat May 28, 2011 11:05 am Post subject: Removing door cards?! |
SORRY if this is a silly question!
I just tried removing door cards but having problems.
how does it remove from the top? Bottom I managed to do... I can see one pin that needs unscrewing only.
I've got 1.1 btw.
Thanks. |
