| Author |
| Ash |
Posted: Sat Jul 02, 2011 1:16 pm Post subject: Re: how to perform an immobiliser reset |
| Check your fuses. |
| Lee |
Posted: Sat Jul 02, 2011 12:25 pm Post subject: Re: how to perform an immobiliser reset |
You can't reset the immobiliser per say as its in the BSI. The only thing you can do is softboot the BSI. And since you have had the battery off overnight you will have done that.
The ring around the ignition is prone to failing. |
| CD-B3 |
Posted: Sat Jul 02, 2011 12:11 pm Post subject: Re: how to perform an immobiliser reset |
| Search soft boot bsi |
| jimmy |
Posted: Sat Jul 02, 2011 11:30 am Post subject: how to perform an immobiliser reset |
my 16 GLX wont start! To cut a long story short, I have no power going to the fuel pump. After replacing the fuel relay and testing the fuel pump (which works fine) I want to reset the immobiliser.
Any ideas on how to do a reset?
I have disconnected the battery for the night and hope in the morning everything will be reset when I re-connect the battery.
Are there any procedures with the key, ignition etc?? |
