Author |
MrBSI |
Posted: Wed Feb 15, 2012 12:16 pm Post subject: Re: Removing 180 Seat Airbag Connector |
sambelsher wrote: |
what resistor do i need to use and what 2 cables do i put it across cuz there is 3 cables |
MOT FAIL
Is your insurance company happy / you bothered to tell them you have removed factory fitted safety equipment from the car? |
sambelsher |
Posted: Wed Feb 15, 2012 6:36 am Post subject: Re: Removing 180 Seat Airbag Connector |
iainlovatt |
Posted: Wed Feb 15, 2012 4:42 am Post subject: Re: Removing 180 Seat Airbag Connector |
HFStuart wrote: |
Turn the connector over from how it's shown in your photo. There's a little green tab that you'll be able to push down and it looks like that frees it - but it doesn't
You need to get a slim screwdriver and slide it in just beneath thab tab - give it a wiggle and the connector can be pulled apart. Took me a while to work it out and I've done a few over the years.
Edit: Camera found - Like this mating half missing but you get the idea.
thats how i got it to come away too! great minds think alike!
Stuart |
LeeThr |
Posted: Tue Feb 14, 2012 9:10 pm Post subject: Re: Removing 180 Seat Airbag Connector |
sambelsher wrote: |
hi i have a simuler problem i remover the standered seats and put some recoro seats in my 206 GTI and i am getting airbag fault is there any way i can join the cables together to make the car think the airbags are still there to get rid of the airbag fault if so what cables do i join together there is 3 cables going to to the plug |
Stick a resistor of the correct value accross the terminals. Or get the airbag ECU disabled. |
sambelsher |
Posted: Tue Feb 14, 2012 7:00 pm Post subject: Re: Removing 180 Seat Airbag Connector |
sambelsher |
rob_1990 |
Posted: Wed Jul 06, 2011 4:31 pm Post subject: Re: Removing 180 Seat Airbag Connector |
HFStuart wrote: |
thanks mate, that worked a treat!
Stuart |
HFStuart |
Posted: Wed Jul 06, 2011 3:56 pm Post subject: Re: Removing 180 Seat Airbag Connector |
Stuart |
Defjester |
Posted: Wed Jul 06, 2011 1:36 pm Post subject: Re: Removing 180 Seat Airbag Connector |
Ive just fitted the Gti 180 seats into my 138 Gti and couldn't get that connection apart either, the red tab snapped off when i lifted it
Has it come out of the part of the runner that's attached to the seat? |
rob_1990 |
Posted: Wed Jul 06, 2011 9:43 am Post subject: Re: Removing 180 Seat Airbag Connector |
Ohh seems extreme. The reason im trying to take the seat out is because its rocking back when i accelerate. When moved it earlier a bolt which had sheared off fell out of somewhere, anyone else had this? |
Lee |
Posted: Wed Jul 06, 2011 9:24 am Post subject: Re: Removing 180 Seat Airbag Connector |
Just use insulated crimps.
The reason why they chop them off and solder and heat shrink them is to stop the airbag fault. Loads of companies do this now. |
copey |
Posted: Wed Jul 06, 2011 8:30 am Post subject: Re: Removing 180 Seat Airbag Connector |
suppose its a good idea, just a ball ache if you plan to remove the seats again |
CD-B3 |
Posted: Wed Jul 06, 2011 7:51 am Post subject: Re: Removing 180 Seat Airbag Connector |
EuroPeugeot wrote: |
CD-530d wrote: |
Lift the tab and pull?
When I had my wiring repaired by Peugeot they cut the connectors out and hard wired it  |
That's what I'm going to do I think.
Disconnect the battery for half hour, cut the wires and hard wire them back in.
That should be fine, right? |
That's what Peugeot did so it must be
(I didn't have any issues with it) |
EuroPeugeot |
Posted: Wed Jul 06, 2011 7:47 am Post subject: Re: Removing 180 Seat Airbag Connector |
CD-530d wrote: |
CD-B3 |
Posted: Wed Jul 06, 2011 7:45 am Post subject: Re: Removing 180 Seat Airbag Connector |
