| Author |
| shady |
Posted: Tue Aug 09, 2011 2:40 am Post subject: Re: How to remove a Peugeot windscreen washer pump |
| the thing is that i have done this step , but still don't know where the water comes from ! it's from inside i guess. so anyway i have to remove it . |
| Rob2859 |
Posted: Sat Aug 06, 2011 7:26 am Post subject: Re: How to remove a Peugeot windscreen washer pump |
| Not sure to be honest. Take the arch lining off and you should be able to see. I would put water in it first and see where the leak is before you bother taking it out |
| shady |
Posted: Thu Aug 04, 2011 4:26 pm Post subject: Re: How to remove a Peugeot windscreen washer pump |
| I think its probably cracked !! But my ques. is from where should i take off the tank from down the car or from inside (under. the hood)?? Cause i think its hard to take it off from inside ? |
| Rob2859 |
Posted: Tue Aug 02, 2011 9:34 am Post subject: Re: How to remove a Peugeot windscreen washer pump |
| If it is leaking from where the pump fits the water tank just twist and pull the pump off and put some silicone around the pump and push it back on. no need to remove the tank unless its cracked. |
| Lee |
Posted: Tue Aug 02, 2011 4:04 am Post subject: Re: How to remove a Peugeot windscreen washer pump |
Take the drivers arch liner out. Disconnect the pipes. There is either one or two 10mm bolts that hold the bottle in place.
On a side note, did you buy a speedo from me on ebay yesterday? |
| shady |
Posted: Tue Aug 02, 2011 3:00 am Post subject: How to remove a Peugeot windscreen washer pump |
hi:
i am shady , i have a leakage in my windscreen washer pump so i need to remove it .. and then fix it by myself .
can anyone here show me the way (step by step) to remove this pump , or you can give me a site in which i can get pictures about how to remove it !? |
