| Author |
| BioCustoms |
Posted: Sat Mar 31, 2012 3:03 pm Post subject: Re: HOW do you take out a Dashboard from the 206? |
| Help use out guys more details cos I'm at it now in pitch black need it out for 8 tomorrow morning n I'm not having any look does the main support come out with the dash |
| devildriverxii |
Posted: Fri Mar 16, 2012 3:27 pm Post subject: Re: HOW do you take out a Dashboard from the 206? |
Is it easy to remove the steering wheel shaft?
I know how to remove the wheel itself. |
| NorthantsBen |
Posted: Fri Mar 16, 2012 3:17 am Post subject: Re: HOW do you take out a Dashboard from the 206? |
Centre console, And bit around hanbreak makes it easier too.
Also speedo, and intake steering wheels shaft out too to make room. |
| devildriverxii |
Posted: Fri Mar 16, 2012 3:15 am Post subject: Re: HOW do you take out a Dashboard from the 206? |
| So apart from the steering wheel and glove box, does anything else have to be removed? |
| NorthantsBen |
Posted: Tue Sep 20, 2011 6:47 am Post subject: Re: HOW do you take out a Dashboard from the 206? |
| BigGreenDave wrote: |
lol thanks Lee ;P im in for a world of hurt STEERING SHAFT ill snap it with my abs  |
come again?????  |
| BigGreenDave |
Posted: Mon Sep 19, 2011 4:15 pm Post subject: Re: HOW do you take out a Dashboard from the 206? |
| Rob2859 |
Posted: Mon Sep 19, 2011 4:13 pm Post subject: Re: HOW do you take out a Dashboard from the 206? |
| Good luck haha |
| Lee |
T is a torx bit
you need 15,20,25,30 and 40 |
| NorthantsBen |
Posted: Mon Sep 19, 2011 4:12 pm Post subject: Re: HOW do you take out a Dashboard from the 206? |
I just done one for a info'er on saturday. Also done few others.
Basically all you need is what Lee said,
You can leave passenger airbag in and remove it once dash is out,
Take the steering wheel shaft / spline part out too, soo much easyer to get dash out,
Get a torx set and you will need some long torx so socket ones won't do the job  |
| BigGreenDave |
Posted: Mon Sep 19, 2011 4:11 pm Post subject: Re: HOW do you take out a Dashboard from the 206? |
thanks but lets pretend im not a machinic for a second T15?
haha
or no how to even spell it  |
| Lee |
Posted: Mon Sep 19, 2011 4:06 pm Post subject: Re: HOW do you take out a Dashboard from the 206? |
T15,20,25,30 and 40
10mm and 1/2 inch socket
And a small flat bladed screw driver |
| BigGreenDave |
Posted: Mon Sep 19, 2011 4:04 pm Post subject: HOW do you take out a Dashboard from the 206? |
so it pretty much explains all im going to take one out tomrrow so i need to know HOW please
what bolts do i need
star keys?
passenger air bag?
fusebox
maybe im in for a hole lot of swearing and sweating
thanks |
