Author Message
ed2k12
PostPosted: Fri Sep 21, 2012 1:14 pm    Post subject: Re: Clock light not working. Replacement bulb didn't work either
Can I ask what bulb you bought as a replacement as I can't find the one I need
roastboeuf
PostPosted: Mon Oct 10, 2011 2:34 pm    Post subject: Re: Clock light not working. Replacement bulb didn't work either
Which connector? I'm pretty handy with a soldering iron
gazza82
PostPosted: Mon Oct 10, 2011 1:42 pm    Post subject: Re: Clock light not working. Replacement bulb didn't work either
The connector has probably come away from the circuit board. I had this on our 206CC .. had to do a small soldering job.
roastboeuf
PostPosted: Mon Oct 10, 2011 12:48 pm    Post subject: Re: Clock light not working. Replacement bulb didn't work either
I checked the old bulb today and it was definitely gone.
Any other ideas?
roastboeuf
PostPosted: Sun Oct 09, 2011 5:41 am    Post subject: Re: Clock light not working. Replacement bulb didn't work either
I have the small one but I have procured the bigger one. Not sure if there is a connector hidden somewhere I could connect to. I will try the multimeter on Monday as I haven't bought one yet but have one at work.
PostPosted: Sun Oct 09, 2011 5:29 am    Post subject: Re: Clock light not working. Replacement bulb didn't work either
What type is it? A small one with just time or bigger?
iainlovatt
PostPosted: Sun Oct 09, 2011 3:34 am    Post subject: Re: Clock light not working. Replacement bulb didn't work ei
the old bulb put a multimetre on it to see if it actually is the broken bulb or broekn display? which display unit is it?
roastboeuf
PostPosted: Sun Oct 09, 2011 3:29 am    Post subject: Clock light not working. Replacement bulb didn't work either
Hey guys,
Bought a y reg 206 1.9 diesel recently. Had a bit of work needed which I have done (new heater motor resistor pack, new drivers door stay, etc). Pretty pleased with myself, however the clock light wasn't working when i bought the car. I picked up a new display unit whilst at the scrapyard but realised it has a fancier one than mine and I don't have the connector for it. So swapped the bulbs across with no luck.
Any ideas guys?
