| Author |
| TheGTIlad |
Posted: Sun Nov 13, 2011 2:32 pm Post subject: Re: Need a how to for Remove-Refit of the timing belt. |
| MrBSI wrote: |
| TheGTIlad wrote: |
| Lee wrote: |
| 60k or 5 years, which ever is first |
If mine is 97k, and the period is 60k or 5 years, is it possible mines had one already or can some last this long on one cambelt? |
Its possible it might still be on the original timing belt. |
She-ite. I know what I'm going to price up asap then. |
| MrBSI |
Posted: Sun Nov 13, 2011 2:27 pm Post subject: Re: Need a how to for Remove-Refit of the timing belt. |
| TheGTIlad wrote: |
| Lee wrote: |
| TheGTIlad |
Posted: Sun Nov 13, 2011 2:21 pm Post subject: Re: Need a how to for Remove-Refit of the timing belt. |
| Lee wrote: |
| Lee |
Posted: Sun Nov 13, 2011 2:19 pm Post subject: Re: Need a how to for Remove-Refit of the timing belt. |
| TheGTIlad |
Posted: Sun Nov 13, 2011 2:09 pm Post subject: Re: Need a how to for Remove-Refit of the timing belt. |
| its 97k, and its a 2001 X plate car originally, changed to a private plate. |
| gazza82 |
Posted: Sun Nov 13, 2011 1:59 pm Post subject: Re: Need a how to for Remove-Refit of the timing belt. |
| What's the mileage on said 138 and how old is the car? Timing belts have a working life of miles or years, whichever comes first. |
| TheGTIlad |
Posted: Sun Nov 13, 2011 1:58 pm Post subject: Re: Need a how to for Remove-Refit of the timing belt. |
| gazza82 wrote: |
kieron posted one on here for a 2.0i which I used for our CC without any problems.
http://www.206info.co.uk/Forums/viewtopic/t=30420.html
I used bolts rather than trying to find the cam lock/pins .. which is exactly how a local Pug specialist recommended I did it ... |
Thank you very much mate! Much appreciated! |
| TheGTIlad |
Posted: Sun Nov 13, 2011 1:22 pm Post subject: Re: Need a how to for Remove-Refit of the timing belt. |
| Lee wrote: |
| Squeal? sure its not the aux belt? |
No im not sure which belt it is, but I cannot find a receipt for a timing belt either so im unsure if its been done or not so might as well change it. |
| gazza82 |
Posted: Sun Nov 13, 2011 10:57 am Post subject: Re: Need a how to for Remove-Refit of the timing belt. |
| Lee |
Posted: Sun Nov 13, 2011 9:57 am Post subject: Re: Need a how to for Remove-Refit of the timing belt. |
| Edward |
Posted: Sun Nov 13, 2011 8:00 am Post subject: Re: Need a how to for Remove-Refit of the timing belt. |
You won't get one. It's quite a big job. ECU needs removing, engine needs shifting off the mounts otherwise the covers won't come off...
A Haynes manual is useful but it does the job in a 307 which isn't as difficult. |
| TheGTIlad |
Posted: Sun Nov 13, 2011 7:52 am Post subject: Need a how to for Remove-Refit of the timing belt. |
Basically as the title says really. Going to buy a timing belt kit as i have an annoying squeel from the timing side of my engine on a 2.0 gti 136.
Any help would be greatly appreciated. |
