| Author |
| BigGreenDave |
Posted: Mon Jan 09, 2012 8:54 pm Post subject: Re: How do you take off the airbag cover on the dashboard? |
| M60SHW wrote: |
| Take a pillow and push the seats right back haha it's painfull |
you sir are the smart man myself i nearly broke my back
thanks guys for your help i ended up snapping 1 into 3 peices and then eventually got one i wanted  |
| Lee |
Posted: Tue Nov 22, 2011 2:50 pm Post subject: Re: How do you take off the airbag cover on the dashboard? |
| D4NTP wrote: |
| Lee wrote: |
| D4NTP wrote: |
Cant believe you told somebody to do that with out stating its f*****g dangerous! do not put and voltage on to the airbag connections!
If they got hurt because of stupid a**e comments like that...f*****g retards. |
They must be f*****g retards if they do it. |
It honestly wouldnt bother you if someone did what you said (however stupid you may think it is) and seriously hurt themselves? |
Not really. Should always use common sense before doing anything. |
| D4NTP |
Posted: Tue Nov 22, 2011 2:23 pm Post subject: Re: How do you take off the airbag cover on the dashboard? |
| Lee wrote: |
| D4NTP wrote: |
| Lecktorious |
Posted: Tue Nov 22, 2011 12:58 pm Post subject: Re: How do you take off the airbag cover on the dashboard? |
| Lee wrote: |
This. |
| Lee |
Posted: Tue Nov 22, 2011 12:19 pm Post subject: Re: How do you take off the airbag cover on the dashboard? |
| D4NTP wrote: |
| MrBSI |
Posted: Tue Nov 22, 2011 11:46 am Post subject: Re: How do you take off the airbag cover on the dashboard? |
| Good thing about the 206 is the passenger airbag is just screwed / bolted on & easy / cheap to replace unlike a lot of cars where the whole dash needs replacing when the passenger airbag fires. |
| D4NTP |
Posted: Tue Nov 22, 2011 11:44 am Post subject: Re: How do you take off the airbag cover on the dashboard? |
| gazza82 |
Pretty sure that the dash is wrecked if the passenger air bag does off. There isn't a seam around the cover so it will tear through it if it goes off.
If you are contemplating touching the airbag system, disconnect the battery and leave it for 15-20 mins to disarm itself. |
| MrBSI |
Posted: Tue Nov 22, 2011 11:20 am Post subject: Re: How do you take off the airbag cover on the dashboard? |
| Lee wrote: |
| Undo the airbag connector and connect the terminals to a 9-14volt battery. That will remove it from it's casing |
Multimeter set to resistance setting will give the same result  |
| Lee |
Posted: Tue Nov 22, 2011 11:16 am Post subject: Re: How do you take off the airbag cover on the dashboard? |
| PugJH |
Posted: Tue Nov 22, 2011 10:46 am Post subject: Re: How do you take off the airbag cover on the dashboard? |
The airbag on the passenger side isnt a cover, its a whole airbag unit.
If thats what you meant.
If not sure its only about 5 screws and a plug you unclip |
| colinn |
Posted: Tue Nov 22, 2011 10:19 am Post subject: Re: How do you take off the airbag cover on the dashboard? |
| Haynes manual identifies the screw locations - when I took mine out I removed glove-box, centre console and the panel at the end of the dashboard first for better access and to get some extra light in there - it's fiddly and you end up lying on your back in the footwell with a torch in your mouth |
| M60SHW |
Posted: Tue Nov 22, 2011 9:59 am Post subject: Re: How do you take off the airbag cover on the dashboard? |
| MrBSI |
Posted: Tue Nov 22, 2011 9:57 am Post subject: Re: How do you take off the airbag cover on the dashboard? |
| BigGreenDave wrote: |
| How!?!? |
Try removing the screws & nuts is a pretty good start. |
| NorthantsBen |
Posted: Tue Nov 22, 2011 9:22 am Post subject: Re: How do you take off the airbag cover on the dashboard? |
as in to replace air bag?
take glovebox out get your arm up there and have a feel for the little torx screws theres also one or two around airvent too. if thats what your on about anyway. |
