| Author |
| obwales |
Posted: Thu Jan 05, 2012 8:42 am Post subject: Re: Replacing throttle cable |
| I hope this is easy. Will attemp at weekend. If anybody knows of any picture guides or videos be much appreciated. Cheers O |
| spike_202 |
Posted: Fri Dec 23, 2011 3:44 am Post subject: Re: Replacing throttle cable |
| nice 1 ben id say even easyer as im on throttle bodys and every thing you need to get to is directley in front of you. |
| NorthantsBen |
Posted: Thu Dec 22, 2011 7:19 pm Post subject: Re: Replacing throttle cable |
Told you it was simple he he |
| spike_202 |
Posted: Thu Dec 22, 2011 3:32 pm Post subject: Re: Replacing throttle cable |
| Done it, it was realy simple to do. As i did it in the dark with a touch couldnt realy take photos, you litraly unclip at the throttle body and unclip at the pedal and 1 split pin just as it passes through the bulk head and its free to pull out took me around 15 in all and that was half of it messin around with the tourch in my mouth lol |
| spike_202 |
Posted: Thu Dec 22, 2011 1:51 am Post subject: Re: Replacing throttle cable |
| Did you replace the outer as well Ben? |
| NorthantsBen |
Posted: Wed Dec 21, 2011 5:12 pm Post subject: Re: Replacing throttle cable |
| well i just done mine on a 1.6 8v and i simply unclipped both ends, and worked it loose. (think there was also a little clip on the rubber bit that comes into the car on the inside also iirc) |
| spike_202 |
Posted: Wed Dec 21, 2011 4:47 pm Post subject: Replacing throttle cable |
Hay guys as title any pics or step buy step on replacing the accelerator cable from the pedal to the throttle body would be grate as I'm doing it to morrow as I found mine is frayed and want it done ASAP.
Thanks all |
