| Author |
| tomd0801754 |
Posted: Sat Apr 28, 2012 10:02 am Post subject: Re: How do you remove the roof...trim? |
| Two screws at the back in between boot and roof iirc. |
| mattvaretto |
Posted: Sat Apr 28, 2012 9:21 am Post subject: Re: How do you remove the roof...trim? |
| There's a rivet at the bottom near the bonnet that you have to pull out then they should slide out backwards. Big emphasis on SHOULD as I haven't actually done this myself! |
| DeadEyePaul |
Posted: Sat Mar 24, 2012 2:56 pm Post subject: Re: How do you remove the roof...trim? |
I was tugging at this yesterday(I'm in a paint and spray mood)
Not sure how to unclog it at the windscreen without breaking anything but I'm interested in knowing how it's done |
| ARRAN |
Posted: Sat Mar 24, 2012 2:22 pm Post subject: Re: How do you remove the roof...trim? |
EDIT: My bad, I misread your post. I'll try again
They clip in down the bottom of the wind screen, then I'm pretty sure they silde out.  |
| devildriverxii |
Posted: Sat Mar 24, 2012 2:13 pm Post subject: How do you remove the roof...trim? |
I had a quick look, but I'm not sure what they're called to do a proper search.
I need to remove the long black bits that go either side of the roof, and down the a pillars.
Any ideas, I don't want to just pull them off.
Also the aerial needs to come off too, that just unscrews from the inside right?
Cheers. |
