| Author |
| alaakaleel |
Posted: Thu Apr 26, 2012 5:16 am Post subject: Re: How can I run the engine cooling fan |
I put temperature sensor Mercedes car running at 85 degrees have become good
thanks for answer |
| Ash |
Posted: Thu Apr 19, 2012 4:51 pm Post subject: Re: How can I run the engine cooling fan |
| MrBSI wrote: |
A better spec of radiator is whats needed here  |
I didn't expect anyone to take my reply seriously  |
| MrBSI |
Posted: Thu Apr 19, 2012 11:01 am Post subject: Re: How can I run the engine cooling fan |
| Ash |
Posted: Thu Apr 19, 2012 10:50 am Post subject: Re: How can I run the engine cooling fan |
Is it always warm in Iraq?
Remove the Thermo and hard wire the fan to a switched live  |
| MrBSI |
Posted: Thu Apr 19, 2012 8:19 am Post subject: Re: How can I run the engine cooling fan |
| alaakaleel wrote: |
my fan it works OK but I need to change started work at 75 or 80 by change the Programming mind of the car.
can I do it ? |
No point running the cooling fan at anything less then 89 deg C as the thermostat will be shut & there will be no coolant flow from the engine through the radiator.
Until the thermostat opens to allow the hot coolant to flow in to the radiator, it & the cooling fan are basically not doing anything to aid engine cooling. |
| craigdmjv |
Posted: Thu Apr 19, 2012 12:47 am Post subject: Re: How can I run the engine cooling fan |
| i know how to sort of do it on a cinquecento if that helps lol |
| alaakaleel |
Posted: Thu Apr 19, 2012 12:02 am Post subject: Re: How can I run the engine cooling fan |
can I do it ? |
| MrBSI |
Posted: Wed Apr 18, 2012 9:18 am Post subject: Re: How can I run the engine cooling fan |
| Seeing as the OP is based in Iraq which is a much hotter climate during the daytime then the UK I would be looking to fit a better spec of radiator for more cooling then trying to make the fan cut in earlier. |
| Edward |
Posted: Wed Apr 18, 2012 5:27 am Post subject: Re: How can I run the engine cooling fan |
| The switch is the ECU though. |
| Seabook |
Posted: Wed Apr 18, 2012 4:14 am Post subject: Re: How can I run the engine cooling fan |
just use the switch in the diesel version.
they kick in at 80degree |
| E5GDM |
Posted: Wed Apr 18, 2012 3:40 am Post subject: Re: How can I run the engine cooling fan |
| Im not sure why you'd want to do that, but unless you can get a cut in switch that operates at that temp or adapt one, a manual switch is the only way. |
| Big_Rich180 |
Posted: Wed Apr 18, 2012 3:19 am Post subject: Re: How can I run the engine cooling fan |
I think he's wanting the fan to cut in at 75-80 deg.
Im not sure how you would do that but I think you could get the fan hooked up to a button and that way you could turn it on when you like. |
| snowonfire |
Posted: Wed Apr 18, 2012 3:15 am Post subject: Re: How can I run the engine cooling fan |
Your a bit unclear on what you are looking for here...
Can you explain what you are trying to do?
Are you testing the fan?
Is the fan broken and you're looking for a fix? |
| alaakaleel |
Posted: Wed Apr 18, 2012 2:56 am Post subject: How can I run the engine cooling fan |
| How can I run the engine cooling fan at a temperature of 75 or 80 degrees in a car Peugeot 206 |
