| Author |
| mastersonkev |
Posted: Sun May 06, 2012 6:31 am Post subject: Re: Replacing the aerial (including base) (back mounted) |
| How do you remove the interior lining? I also need to replace my rear-mounted aerial. |
| mtempsch |
Posted: Wed Apr 25, 2012 11:27 pm Post subject: Re: Replacing the aerial (including base) (back mounted) |
| Timon2210 wrote: |
by the way,why it got 2 cables in this pic? |
I'd assume actual antenna wire + a 12V line to power amplifier in the base |
| Squeaker |
Posted: Wed Apr 25, 2012 3:10 pm Post subject: Re: Replacing the aerial (including base) (back mounted) |
No idea why its got 2 wires But it came off my Hdi Gti  |
| Timon2210 |
Posted: Wed Apr 25, 2012 1:38 pm Post subject: Re: Replacing the aerial (including base) (back mounted) |
I can help fitting this with you my friend,give me a PM and I will tell you how to do it :D.
| Squeaker |
Posted: Wed Apr 25, 2012 12:10 pm Post subject: Re: Replacing the aerial (including base) (back mounted) |
You need to pull the roof lining down a bit, then as you can see in this pict
The base has a bolt in it, there is just a nut which unscrews and the base should just lift off. |
| omricn |
Posted: Wed Apr 25, 2012 10:48 am Post subject: Re: Replacing the aerial (including base) (back mounted) |
| MrZiggerz wrote: |
You do it, and take pictures and post how you did it  |
Actually I'm ordering a base right now, and that's exactly what I was thinking that if no one will post a how-to than I will  |
| MrZiggerz |
Posted: Wed Apr 25, 2012 9:51 am Post subject: Re: Replacing the aerial (including base) (back mounted) |
| omricn |
Posted: Wed Apr 25, 2012 9:50 am Post subject: Replacing the aerial (including base) (back mounted) |
Can someone please post a how to of removing the aerial base please?, my aerial is not removable at the moment because it's bolts are corroded and I have to replace the whole thing..
TNX  |
