| Author |
| marc206 |
Posted: Mon Jun 04, 2012 7:19 am Post subject: Re: How do i remove the door handles |
| colour code the ones you have on at the mo? just newspaper and tape the surrounding area first |
| JordGJ |
Posted: Mon Jun 04, 2012 6:48 am Post subject: Re: How do i remove the door handles |
| Good idea to take the door card off anyway because as you drill the rivets out metal bits fall inside the door and rattle around if you dont get rid of them. Depends how fussy you are. I bolted mine back on, does the same job and its easy to take off if they ever need to come off again. |
| MrBSI |
Posted: Mon Jun 04, 2012 5:54 am Post subject: Re: How do i remove the door handles |
| seany_brown wrote: |
| do you get to them from the inside (take door card off) |
Nope, lift the handle up & you should then spot your target for the drill  |
| seany_brown |
Posted: Mon Jun 04, 2012 5:44 am Post subject: Re: How do i remove the door handles |
| MrBSI |
Posted: Mon Jun 04, 2012 5:24 am Post subject: Re: How do i remove the door handles |
| so i gotta use my rivet gun to put them back in too ? cheers MrBSI |
You have a rivet gun so you might aswell use it  |
| Harry |
Posted: Mon Jun 04, 2012 5:23 am Post subject: Re: How do i remove the door handles |
| I've bolted mine back on, works as long as you have a large selection of lengths and heads as some I tried didn't allow it to sit fully closed |
| seany_brown |
Posted: Mon Jun 04, 2012 5:22 am Post subject: Re: How do i remove the door handles |
| MrBSI |
Posted: Mon Jun 04, 2012 5:19 am Post subject: Re: How do i remove the door handles |
| A cordless drill & some suitable drill bits as the handles are held in with rivets. |
| seany_brown |
Posted: Mon Jun 04, 2012 5:18 am Post subject: How do i remove the door handles |
how do i remove the outside door handles, as i want to get colour coded ones, but dont know what tools to take to the scrap yard!
Thanks lads |
