| Author |
| anton1989 |
Posted: Sat Sep 22, 2012 8:09 pm Post subject: Re: Top brake light removal |
mine will not come out for s**t!!!!!!
i had to force my one on my last car that came out in the end but the one on my newer 206 will not move, reckon i might have to brake it! only want it out as its not working |
| DeadEyePaul |
Posted: Sat Sep 22, 2012 3:04 pm Post subject: Re: Top brake light removal |
| MrBSI wrote: |
| Put the nuts back on loosely to protect the studs then a few gently taps on them should unstuck the lamp unit. |
this worked for me, but instead of putting nuts on I rested the flat part of a spanner over the bottom of the bolts and tapped the spanner with a hammer. either way works  |
| top206 |
Posted: Sat Sep 22, 2012 1:45 pm Post subject: Re: Top brake light removal |
| i think ive still got the original brake light for that. |
| L5_UKS |
Posted: Fri Jun 29, 2012 9:47 am Post subject: Re: Top brake light removal |
Cheers guys, I took your advice and it came out a treat  |
| mtempsch |
Posted: Fri Jun 29, 2012 7:23 am Post subject: Re: Top brake light removal |
| lukesaunders91 wrote: |
I didn't want to really force it incase there was something else holding it in?
Nothing other than the rubber gasket having become rather fond of both the lamp and boot lid...
See previous posters for how to proceed. |
| sulli |
Posted: Fri Jun 29, 2012 6:24 am Post subject: Re: Top brake light removal |
| If that doesn't work as it didn't on mine I got a piece of a cardboard to protect the paint and a small screw driver and pryed it out. |
| MrBSI |
Posted: Fri Jun 29, 2012 5:04 am Post subject: Re: Top brake light removal |
| L5_UKS |
Posted: Fri Jun 29, 2012 4:57 am Post subject: Top brake light removal |
Hi,
Had a search as thought this would be already covered but it appears not?, basically I'm trying to remove my top bake light the long one along the time. Opened boot removed 2 bolts thinking it would just push up put it won't move I didn't want to really force it incase there was something else holding it in?
Thanks in advance. |
