Author Message
very_452001
PostPosted: Mon Jul 09, 2012 8:38 am    Post subject: Re: How do I change the crank sensor?
V9977 wrote:
Very very easy. I always did it without taking anything else out on 1.4i.
But why replace it? Do you suspect it has failed?
because the garage said it needs to be replaced to resolve the intermittent problem.
PostPosted: Sun Jul 08, 2012 11:14 am    Post subject: Re: How do I change the crank sensor?
cartoonhead
PostPosted: Fri Jul 06, 2012 4:10 pm    Post subject: Re: How do I change the crank sensor?
from another post
very_452001 wrote:
ps its a 2006 peugeot 206 1.4 verve
PostPosted: Fri Jul 06, 2012 4:05 pm    Post subject: Re: How do I change the crank sensor?
Which car?
Chances are it's just a 10mm bolt holding it onto the gearbox. You'll need to take the battery and box out to access it though.
very_452001
PostPosted: Fri Jul 06, 2012 3:59 pm    Post subject: How do I change the crank sensor?
Is it a quick job and what tools are quired?
Cheers,
