| Author |
| Rob2859 |
Posted: Sun Aug 05, 2012 4:03 pm Post subject: Re: Fog light bumper install |
| Lee wrote: |
| Domo wrote: |
Wats up with the mov 0327 or sumthing like that. Also do the fogs keep flashin in that first mode? |
Laptop was f****d, needed a new motherboard I think...can't remember.
Yeah they flashed in one of the modes  |
Pretty smart but they will reduce the life of the bulbs so I have been told. You shouldn't play with it too much  |
| anton1989 |
Posted: Sun Aug 05, 2012 2:46 pm Post subject: Re: Fog light bumper install |
rubbish
| Lee |
Posted: Sun Aug 05, 2012 12:14 pm Post subject: Re: Fog light bumper install |
| Domo wrote: |
| Domo |
Posted: Sun Aug 05, 2012 12:08 pm Post subject: Re: Fog light bumper install |
| MrBSI |
Posted: Sun Aug 05, 2012 11:23 am Post subject: Re: Fog light bumper install |
| macca1411 wrote: |
Just get a switch, relay and fuse and wire them in that way. It's an easy enough job if you know what you're doing. |
| Lee |
| Domo |
Posted: Sun Aug 05, 2012 9:56 am Post subject: Re: Fog light bumper install |
Yea but dnt knOw wat im doing haha. Was hopin for easy fix.  |
| macca1411 |
Posted: Sun Aug 05, 2012 9:40 am Post subject: Re: Fog light bumper install |
| anton1989 wrote: |
| QuArTz wrote: |
| anton1989 wrote: |
| just wire them to highbeam? or low |
If he wires them into the headlights, its more than likely he'll get pulled by the police.
Ive been pulled over for having my fogs on when it wasn't foggy.. |
highbeam/full beam is fine, no one drives with full beam on so they will only be on when needed |
Put main beam on in fog and you seriously reduce visibility for yourself.
The beam pattern for fog lights is designed to cut through the fog and increase the visibility for the driver. They are not driving lights and offer very little usable light on unlit roads where main beam is needed.
Wire them up to dipped beam and risk a FP for driving with auxiliary lights illuminated when visibility isn't reduced.
| anton1989 |
Posted: Sun Aug 05, 2012 8:23 am Post subject: Re: Fog light bumper install |
| QuArTz wrote: |
| anton1989 wrote: |
| Domo |
Posted: Sun Aug 05, 2012 8:05 am Post subject: Re: Fog light bumper install |
I think they wer wired up to a stirk(if thats the indicatir type switch) but then have been disconnected. I cnt even try fix atm only have one useable hand  |
| iainlovatt |
Posted: Sun Aug 05, 2012 7:05 am Post subject: Re: Fog light bumper install |
| i wired mine upto a separate switch, was ok but its a hell of a lot easier to wire it into high beam, makes sense too, |
| -Dave- |
Posted: Sun Aug 05, 2012 6:20 am Post subject: Re: Fog light bumper install |
| If you want to connect them up via a stork you need to see if you have the fuse for it first I believe. Easiest way to do it is to wire them up to a separate switch in the car. |
| Domo |
Posted: Sun Aug 05, 2012 6:05 am Post subject: Re: Fog light bumper install |
| So theres no easy fix. Slot plug A into slot 3 type thing? |
| QuArTz |
Posted: Sun Aug 05, 2012 5:49 am Post subject: Re: Fog light bumper install |
| anton1989 wrote: |
| anton1989 |
Posted: Sun Aug 05, 2012 4:05 am Post subject: Re: Fog light bumper install |
