Author |
MrBSI |
Posted: Fri Nov 09, 2012 5:10 pm Post subject: Re: How to Fit Seatbelt Warning Function |
SteDuval1985 wrote: |
MrBSI wrote: |
You need to see if the 2 pin white connector plug is hidden under the carpet below the drivers seat first before going any further.
You need the buckle with the built in sensor.
You need to tweak the BSI setup configuration.
Also RESPECT for using the SEARCH |
Did you have to remove the seat to check? |
How else are you going to get under the carpet to play hunt the wiring loom? |
iainlovatt |
Posted: Fri Nov 09, 2012 10:51 am Post subject: Re: How to Fit Seatbelt Warning Function |
Of course unless you have the smallest hands in the world and can twist them in multiple angles, |
SteDuval1985 |
Posted: Fri Nov 09, 2012 8:07 am Post subject: Re: How to Fit Seatbelt Warning Function |
MrBSI wrote: |
MrBSI |
Posted: Fri Nov 09, 2012 8:05 am Post subject: Re: How to Fit Seatbelt Warning Function |
iainlovatt wrote: |
I had mine disabled, it did my head in, but a query with regards to this, can you make it so the passenger one works, does anyone know if the loom is there? it is as far as the seat goes, but i have always wondered if there is one under the carpet. |
Wasnt in my 2003 vintage 206, just the side airbag loom hidden under the carpet below the passenger seat.
Side airbags & seat belt warning where both easy retrofits for me |
iainlovatt |
Posted: Fri Nov 09, 2012 8:02 am Post subject: Re: How to Fit Seatbelt Warning Function |
MrBSI |
Posted: Fri Nov 09, 2012 8:00 am Post subject: Re: How to Fit Seatbelt Warning Function |
SteDuval1985 |
Posted: Fri Nov 09, 2012 7:54 am Post subject: How to Fit Seatbelt Warning Function |
How can I install this? What parts do I need?
Saw that Mr BSI had done it in this thread...
www.206info.co.uk/Foru...light.html |
