Author Message
anton1989
PostPosted: Sat Nov 10, 2012 11:47 am    Post subject: Re: how to remove door window (with no power)
Yh mate all sorted Very Happy p**s easy to remove!
Cheers
iainlovatt
PostPosted: Sat Nov 10, 2012 10:22 am    Post subject: Re: how to remove door window (with no power)
you manage to do it?
iainlovatt
PostPosted: Sat Nov 10, 2012 7:53 am    Post subject: Re: how to remove door window (with no power)
I did it on an MX5 to test the window mech in a scrapyard, plus i have done it on a 206. So it will work, Pos to one pin in conection block and neg to the other pin in connection block, simple switch the circuit for it to the opposite way. Simples
anton1989
PostPosted: Sat Nov 10, 2012 7:45 am    Post subject: Re: how to remove door window (with no power)
Yeah that make sense will give it ago cheers
iainlovatt
PostPosted: Sat Nov 10, 2012 7:35 am    Post subject: Re: how to remove door window (with no power)
Anton get a battery and 2 cables and make a connection from battery to connection block on window mechanism. U will need to use pos and neg on battery, reverse them switch over on battery to make window go the opposite way.
That make sense?
anton1989
PostPosted: Sat Nov 10, 2012 7:21 am    Post subject: Re: how to remove door window (with no power)
No mate they have not. I wanted to keep them as they are tinted along with the quater ones
PostPosted: Sat Nov 10, 2012 7:06 am    Post subject: Re: how to remove door window (with no power)
Have the scrapyard asked you to remove it, or have you sold it.
Simple answer if it's scrap is to smash it. If you have sold it, take a hacksaw to the frame, either that or remove the workings from the door and work the window down with hand pressure once the mechanism is disconnected.
anton1989
PostPosted: Sat Nov 10, 2012 6:49 am    Post subject: how to remove door window (with no power)
A car I have been breaking is going scrap yard today but I need to remove the door glass?
I did a search and found u need to move the window down and remove the seal around the door BUT I can not get power to the window Surprised
Help please car is going today!
