| Author |
| mtempsch |
Posted: Sun Aug 23, 2015 1:24 am Post subject: Re: Cleaning Rear Lights |
| Suggy wrote: |
| Will this work on the front lights? |
Sure. I'd remove the electrical adjuster from the housing before starting with the water.
I'd leave out the grainy stuff, the reflectors are both more visible in the fronts and the light pattern way more important than the rears - don't want scratches.
I'd probably use pure alcohol or alco/distilled water mix as the final rinse as it evaporates faster than plain water and distilled water has no dissolved minerals that can cause spots. |
| Suggy |
Posted: Sat Aug 08, 2015 10:25 am Post subject: Re: Cleaning Rear Lights |
| RoweY |
Posted: Thu Feb 14, 2013 2:10 pm Post subject: Re: Cleaning Rear Lights |
Yes it worked really well, thanks  |
| Timon2210 |
Posted: Thu Feb 14, 2013 1:29 pm Post subject: Re: Cleaning Rear Lights |
| how did it go? |
| RoweY |
Posted: Sat Feb 02, 2013 2:43 pm Post subject: Re: Cleaning Rear Lights |
Thanks for the advice i'll give that a go in the morning!  |
| Timon2210 |
Posted: Sat Feb 02, 2013 2:32 pm Post subject: Re: Cleaning Rear Lights |
The effective method is this:
1-Take them off.
2-Take the bulbs base off.
3-get warm water in a bucket.
4-Add to it Soap (used for dishes cleaning)..lol
5-add a cup of washing powder (one with Grains).
6-Mix them very well,and get a cup and fill the lights with the warm water.
7-shake them hard,and for like 5 min. each.
8-rinse them ,and make sure to keep them dry without sunlight or u will have stains on the lens. |
| jk206 |
Posted: Sat Feb 02, 2013 10:00 am Post subject: Re: Cleaning Rear Lights |
Burn them, job done.
Jokes aside, see I you can separate them? Or even rinse water In them, pour it out and let them dry out |
| RoweY |
Posted: Sat Feb 02, 2013 9:56 am Post subject: Cleaning Rear Lights |
Any advice on how i could clean dirt out of my rear lexus lights ? Thanks  |
