Author Message
adzar
PostPosted: Thu Sep 26, 2013 10:34 am    Post subject: Re: Request: How to change the head gasket of a 1.4 16v (ET3J4)
Question for re-assembly:
The haines manual gives the inlet sprocket retaining bolt torque as:
stage 1 = 20Nm
stage 2 = 60Nm
What is the procedure for tightening a single bolt in two stages?
There doesnt appear to be any specific reference to the two torques in the manual as there was for the head gasket bolts for instance.
tlsjk
PostPosted: Wed Sep 11, 2013 2:40 pm    Post subject: Re: Request: How to change the head gasket of a 1.4 16v (ET3J4)
if you need a how to then you SHOULDNT be doing it!!!
adzar
PostPosted: Wed Sep 11, 2013 10:49 am    Post subject: Re: Request: How to change the head gasket of a 1.4 16v (ET3
adzar wrote:
Does anyone know what size/type of socket to use on the head gasket bolts? They are a 6 pointed star shape.
E-14 is the answer
PostPosted: Sat Sep 07, 2013 8:30 am    Post subject: Re: Request: How to change the head gasket of a 1.4 16v (ET3J4)
You need to change the bolts as there stretch type i.e. you can only use them once.
adzar
PostPosted: Sat Sep 07, 2013 5:06 am    Post subject: Re: Request: How to change the head gasket of a 1.4 16v (ET3J4)
I can only see the bolt length to check for and torques in Haynes.
PostPosted: Sat Sep 07, 2013 4:40 am    Post subject: Re: Request: How to change the head gasket of a 1.4 16v (ET3J4)
There is a good guide in the Haynes manual Wink
PostPosted: Sat Sep 07, 2013 4:18 am    Post subject: Re: Request: How to change the head gasket of a 1.4 16v (ET3J4)
If you can't spot a torx head on a bolt you're out of your depth doing a head gasket change. I would guess you don't have a torque wrench either?
adzar
PostPosted: Sat Sep 07, 2013 3:32 am    Post subject: Re: Request: How to change the head gasket of a 1.4 16v (ET3
PostPosted: Sat Apr 27, 2013 5:30 pm    Post subject: Re: Request: How to change the head gasket of a 1.4 16v (ET3J4)
Im not yet mate Wink
PostPosted: Sat Apr 27, 2013 12:39 pm    Post subject: Re: Request: How to change the head gasket of a 1.4 16v (ET3J4)
Addaz wrote:
Give me a couple of days and I will post up a full guide
What are you doing with one of these engines?!! Laughing
adzar
PostPosted: Sat Apr 27, 2013 11:49 am    Post subject: Re: Request: How to change the head gasket of a 1.4 16v (ET3
Amazing, thanks very much!
PostPosted: Sat Apr 27, 2013 11:16 am    Post subject: Re: Request: How to change the head gasket of a 1.4 16v (ET3J4)
adzar
PostPosted: Sat Apr 27, 2013 10:31 am    Post subject: Request: How to change the head gasket of a 1.4 16v (ET3J4)
Does anyone have a how-to/guidance on changing the head gasket of a 1.4 16v sport (ET3J4)?
Would be very much appreciated.
