| Author |
| eddie206 |
Posted: Sat Jul 06, 2013 7:25 am Post subject: Re: Front Bumper Help |
Just hacksaw the two off..but protect the paint with a few strips of maskin tape...cuts off in 1-2 mins each...dead easy..
As for the torx bolts under the inner edges of the headlites get the right torx bit and tightly grip with mole grips and spanner action them out..problem there otherwise .. |
| danlouiee |
Posted: Sat Jul 06, 2013 5:41 am Post subject: Re: Front Bumper Help |
Get someone underneath with some grips to hold it and someone else undo it but need to hold grips real tight..before it's put back together make sure you wire brush the thread of the nut and bolt and oil it with wd40 (or other products are available ) and then put the bolt on the but undo it again then refit to bumper  |
| dan1995206 |
Posted: Sat Jul 06, 2013 3:58 am Post subject: Re: Front Bumper Help |
Thats the plan  |
| Tolkienfan001 |
Posted: Sat Jul 06, 2013 3:39 am Post subject: Re: Front Bumper Help |
Lol common issue! Cut it off and get a new bolt!  |
| dan1995206 |
Posted: Sat Jul 06, 2013 1:47 am Post subject: Re: Front Bumper Help |
| After spending 20 minutes with the same bolt just spinning around that was a option! |
| Tolkienfan001 |
Posted: Sat Jul 06, 2013 1:08 am Post subject: Re: Front Bumper Help |
The quickest way is to get a couple of friends, then each tie a rope round your shoulders then to the bumper. Next leave the handbrake on and at the same time you all run away from the car really fast!
A more sensible option is to use the search option at the top left and use the guide for fitting a front grille. It's really easy to follow. You need to help yourself a bit with these jobs dude. The information is there you just need to look for it
www.206info.co.uk/Foru...grill.html |
| dan1995206 |
Posted: Fri Jul 05, 2013 5:15 pm Post subject: Front Bumper Help |
| Hi, just wondering what is the quickest way to remove the front bumper as i have to colour code my front bumper? |
