| Author |
| macca1411 |
Posted: Mon Jul 22, 2013 5:18 am Post subject: Re: how to take of drivers door |
| Unscrew the check strap, disconnect the wiring harness. Have someone support the door and remove the hinge pins. |
| pug206lx |
Posted: Sun Jul 21, 2013 6:57 pm Post subject: Re: how to take of drivers door |
| the way that I did it is to remove the wing, which gives access to the torx bolts behind. The whole hinge comes with it then. You need to disconnect the wiring and the torx bolt on the check strap also. There may be an easier way to do it, but this is how i did it. |
| marshy206 |
Posted: Sun Jul 21, 2013 8:45 am Post subject: how to take of drivers door |
| Hi i need to take my drivers door of is it easy to do and how do you do it |
