Author |
sheerness |
Posted: Sun Oct 20, 2013 11:45 am Post subject: Re: Removing BSI... |
Thanks for that,
the reason I am replacing BCI/ECU is because my alternator had died then the whole car died on the M25, AA Come out car would not start again, also a solid Engine management light Is on, I have replaced ECU Relay and all fuses, put in new coil pack replaced sensors ect ect, still got the same problem, the only thing left is the ECU/BSI, PP2000 can not get the ecu to reply anymore so ordered another which will be here Tuesday,
Regards
Dom..... |
Addaz |
Posted: Sun Oct 20, 2013 11:33 am Post subject: Re: Removing BSI... |
Why? I dont understand the replacement?
9999 will be substantial for the build code. |
sheerness |
Posted: Sun Oct 20, 2013 11:23 am Post subject: Re: Removing BSI... |
Hi there thanks for your reply,
My Car Is a W Reg 2000 I Will be replacing both ECU & BSI,
The other ECU/BSI Is from a V Reg car,
Also does anyone out there know if I can get the "DAM" number from the donor car that is no longer around, I know the reg and the vin numbers but needing to know the dam number so I can use the diagnostic equipment,
again thanks for taking the time is reading my posts and helping me,
Kind Regards
Dom..... |
Addaz |
Posted: Sun Oct 20, 2013 11:05 am Post subject: Re: Removing BSI... |
Posted a reply in your other thread, there is no need at all for a bsi or ecu by any means |
Addaz |
Posted: Sun Oct 20, 2013 11:00 am Post subject: Re: Removing BSI... |
What year? And new or second hand? |
sheerness |
Posted: Sun Oct 20, 2013 9:16 am Post subject: Removing BSI... |
Hi 206 Friends,
I Have been having problems with my car for 2 weeks now, (please see other posts)
I Have Ordered a BSI & ECU i can take out the ECU no problem, but needing some advise on removing the BSI, i have looked on you tube but all that is there is for a 306 so its installed different to my 206, does anyone here know where i can go and see a video or some advice on removing BSI, I Dont Fancy Taking the whole dashboard out again,
any advice on this would be FAB
thanks in advance friend's
Dom..... |
