| Author |
| Dragas |
Posted: Wed Feb 26, 2014 3:55 pm Post subject: Re: PIN Code in BSI |
| Ok thanks all |
| qwert |
Posted: Tue Feb 25, 2014 2:07 pm Post subject: Re: PIN Code in BSI |
| you need to read the flash or eeprom on a bench. Can't be done by OBD |
| Addaz |
Posted: Mon Feb 24, 2014 5:27 pm Post subject: Re: PIN Code in BSI |
| You cant reset the pin/trans code. One time only unless you get a specialist to remove the imbolliser function off the circuit board |
| Timon2210 |
Posted: Mon Feb 24, 2014 4:54 pm Post subject: Re: PIN Code in BSI |
| Well NEVER use the PP2000 clone to do any update to your BSI,as it's very risky,and you might end with have no working BSI at all,and you will have to replace it with a new one,so I recommend that you visit the Dealer in this case,as it's the safest option. |
| Dragas |
Posted: Mon Feb 24, 2014 4:20 pm Post subject: PIN Code in BSI |
Hello
I`ve a BSI version B2 removed from a 2000 Peugeot 206 1.6 GTI. I want install it in my car but i don`t know de pin code of this BSI... I need unlock that or put another PIN.
I`ve the cable for Lexia/PP2000 but in PP2000 doesn`t have the possibility to change PIN or to see the PIN saved in BSI... Do you know another program to read the PIN and change it using Lexia/PP2000 cable?
This is the used cable...
Thanks |
