| Author |
| uttz |
Posted: Mon Oct 06, 2014 7:29 pm Post subject: Re: Remove the Hub assembly 206 |
| loosening the subframe bolts helps also, not all the way but enough to drop it a little lower |
| gazza82 |
Posted: Sun Oct 05, 2014 5:50 pm Post subject: Re: Remove the Hub assembly 206 |
Depends how long old ones have been on
Also may need to slightly open up gap where clamp bolt goes. They get overtightened and hold on |
| AWK-53 |
Posted: Sun Oct 05, 2014 6:04 am Post subject: Re: Remove the Hub assembly 206 |
| Same as Edward says |
| Edward |
Posted: Sat Oct 04, 2014 12:37 pm Post subject: Re: Remove the Hub assembly 206 |
| I just undo the lower bolt and push down on the wishbone with my foot |
| gazza82 |
Posted: Sat Oct 04, 2014 11:55 am Post subject: Re: Remove the Hub assembly 206 |
I use a long piece of 4x2 (hardwood). One end under floor, over the arm and sticking out under bumper ... and stamp on it  |
| ishmael123 |
Posted: Sat Oct 04, 2014 11:10 am Post subject: Remove the Hub assembly 206 |
| Straggle to remove a front lower ballpoint of 206, model 2006 to able to remove hub assembly |
