| Timon2210 |
Posted: Sun Apr 23, 2017 2:50 pm Post subject: Re: Retrofit AC unit |
Well it's a very hard job to do,and lots of parts needed and lots of work too,as you have to take the dashboard out of the car,so that you can install the A/C unit there,and get the pipes out to the engine bay.
If you really want to do such a job,you need to have a donor car (1.1) same year model so it got the same electric system,and take both cars apart,and start moving parts as if it was a Lego,this way you will have a perfect working unit,and less troubles.
But if I were you,I would just buy a car with original A/C fitted.
Good Luck |
