| Author |
| Sim |
Posted: Sat Mar 23, 2019 10:39 am Post subject: Re: Clutch cable replacement on pug 206 1.4 8v (2000 Reg) |
Your new clutch cable will come with the plastic bracket and the rubber grommet, so this should just come off easily, unless something is stuck on the other side.
By the way, many forum posts warn to carefully follow installation steps of the new cable if it's your first time replacing it www.206info.co.uk/Foru...tml#641631 |
| Bluepug1 |
Posted: Sun Mar 17, 2019 2:35 pm Post subject: Re: Clutch cable replacement on pug 206 1.4 8v (2000 Reg) |
That exact what I did, cable still won't pull off from bulkhead and i cut off old cable only left is that cable end plasic thing that need to be taken off and fit new cable.
I cut off old cable only left is this picture how can i rid this thing off
| Sim |
Posted: Sat Mar 16, 2019 7:42 pm Post subject: Re: Clutch cable replacement on pug 206 1.4 8v (2000 Reg) |
It's at the very top of the pedal, see Haynes picture 3.3 should hopefully clear things up:
| Bluepug1 |
Posted: Sat Mar 16, 2019 3:41 pm Post subject: Clutch cable replacement on pug 206 1.4 8v (2000 Reg) |
Hi all, When I try take off the clutch cable it stuck I cannot find clip to release the cable. I watched Youtube in french pug 206 has a clip on cable under pedal to release clutch cable but that is on left hand not on right-hand car that i unable to find.
I have cut off the cable only left is that metal tube with plastic and rubber that i have torn off on 1st pic how Can I remove it?
Sorry I am not good writing English.
This is cable release clip
Where is it? xD
