Online Now [173]:
Visitors: 172
Today: 93644
Total: 117450378
Forums › The Car › 206 Problems › BSI Reset & Battery Clip Issue
206driver
PostPosted: Fri Dec 10, 2010 2:03 pm Up
Can someone please explain how to do a bsi reset? The search function on this site is tricky - I can never find what im looking for!
I have a 206 X reg (2000)
Over the past few months the + connecter of my battery just comes off and the car doesn't show any signs of life... obviously. I just put it straight back on, dont reset anything and drive off.. but was told i should do this bsi reset!
Peugeot 206 1.9D LX 2000 0-60... 10 minutes!
PostPosted: Fri Dec 10, 2010 2:05 pm Up
Disconnect the negative on the battery, then the positive.
Leave for a few minutes
Reconnect the positive, then the negative
panason1c
PostPosted: Fri Dec 10, 2010 3:10 pm Up
Here is the FULL procedure.......
Put the driver's window down, lift the bonnet and ensure all equipment is switched off.
Ensure all doors are closed and remove key from the ignition.
Wait for 3 minutes, disconnect the vehicle battery and wait 15 seconds.
Reconnect the vehicle battery, wait a further 10 seconds (do not open doors.).
Switch on the side lights through the driver's window.
Switch on the ignition and check system's functionality.
Hold lock button on key down for 10 seconds.
Remove key open & close door test central locking system.
Start the engine and complete the system's check.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
It's not mux Wink
panason1c
PostPosted: Fri Dec 10, 2010 3:31 pm Up
Ah, sorry, my mistake!, i thought the full reset applied to all bsi equipped vehicles.
BMW K1200RS
