Latest: S2cgm
Overall: 17178
Online Now [129]:
Visitors: 127
Bots: 2
Today: 103179
Total: 135998292
Forums › The Car › 206 Problems › Lights gone crazy
Lights gone crazy
SteveM
PostPosted: Sat Dec 11, 2010 10:13 am Up
Hi all,
All my lights have gone a bit weird.
1. When going to first selection on the stalk for my headlights the outside bulb on my drivers side cluster comes on but not passenger side.
2. When going to the second setting on the stalk the passenger side main light comes on but not the drivers side, however the outside bulb stays lit.
3. When on full beam both main bulbs illuminate as they should.
Weird...............I think so!!!
Any ideas out there?
206 2.0 D Turbo (V)
PostPosted: Sat Dec 11, 2010 11:15 am Up
Standard or aftermarket?
SteveM
PostPosted: Sat Dec 11, 2010 11:17 am Up
All completely standard. No mods been done at all, its almost virginal infact!!
206 2.0 D Turbo (V)
PostPosted: Sat Dec 11, 2010 11:19 am Up
Just read it properly
Your passenger sidelight sounds like its blown, and your drivers dipped beam bulb sounds like its blown
SteveM
PostPosted: Sat Dec 11, 2010 11:50 am Up
I've changed the main bulbs before, its a simple job even for the novice. If its other bulbs do I need a new cluster or is it easy enough to disassemble them?
206 2.0 D Turbo (V)
PostPosted: Sat Dec 11, 2010 11:58 am Up
The side light is even easier Laughing
Its just a brown bulb holder that is accessible from the rear of the light, turn it 1/4 of a turn and pull. Then just swap the bulb Smile
SteveM
PostPosted: Sat Dec 11, 2010 1:22 pm Up
Forgive my ignorance lee. By sidelight do you mean the outer light me the headlamp or the side repeater (on the wing)
206 2.0 D Turbo (V)
PostPosted: Sat Dec 11, 2010 1:27 pm Up
SteveM wrote:
Forgive my ignorance lee. By sidelight do you mean the outer light of the headlamp or the side repeater (on the wing)
SteveM
PostPosted: Sun Dec 12, 2010 11:35 am Up
Correct guys. Thanks, should have checked the obvious myself really but that dipped beam is a nightmare (until You realised the washer tank pipe comes off).
206 2.0 D Turbo (V)
