Latest: Andyblue64
Overall: 17123
Online Now [484]:
Visitors: 483
Today: 33763
Total: 98402500
Forums › The Car › 206 Problems › A puzzel / problem (moving an engine)
Go to page 1, 2, 3  Next
PostPosted: Mon Dec 13, 2010 12:05 pm Up
Hi guys, well I've got a bit of a problem.
I've got a 206 that I'm breaking & I've sold the engine, however I don't have an engine crane.
Its been dropped out of the car via a jack & blocks of wood, and its now sitting on blocks of wood.
Now I need get the engine out from under the car & up my driveway so a courrier can collect it from the road.
But as I said I don't have an engine crane. But problem is the driveway is all gravel, so a pallet truck won't roll.
I can possibly get some help & man handle it onto a pallet, but then the pallet needs moving up the drive.
I have access to:
Blocks of wood.
A trolley jack
Wooden boards
A pallet truck
An angle grinder.
A pallet
Here's how it currently sits.
So how would you reccomend I move it?
I've got an idea in mind but its a bit long winded.
The person that works out the solution wins a part from the 206 up to the value of £20, or some other goodies Smile
PostPosted: Mon Dec 13, 2010 12:09 pm Up
Can't you just get a few of you to lift the car up, and roll it over onto its roof? Surely its not that heavy with most of the body panels took off.
Then just wack the engine on a pallet and drag it up the yard
ExoVyper
PostPosted: Mon Dec 13, 2010 12:10 pm Up
can you not dig the gravel out in two channels and put the blocks of wood in so you can make a temporary road for yourself?
then you could just roll the pallet truck out over them
Mrs_Howey
i would say use the wood to leaver it up to the get the trolley jack under neath to get it up off the floor, of course i would say get a couple of people to help you keep it on the trolley jack, if you have enough wooden boards, line them up down the drive, and try to move the jack down the wooden boards, and also put the pallet at the end of the drive,
Or you could man handle it into the 206 your breaking and roll the 206 down the drive (if it has wheels) and then left it out on to the pallet.
I'll keep thinking how else you could do it Very Happy
I can see the pic now, could you not jack the car up and put it on axle stands surely that should give you just enough room to move it out
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
PostPosted: Mon Dec 13, 2010 12:12 pm Up
Lift the body up over the engine with a few friends & roll it backwards.
Put the wooden boards down on top of the gravel for the pallet truck.
Lift the engine on to the pallet.
Pick it up with the pallet truck & roll it where needed.
OR
Borrow a counter balance truck & all your problems are solved Wink
We did attempt to lift the front of it but its pretty heavy still.
There is a small pond behind the car so it cant be rolled backwards.
I'm thinking of cutting the front out with the angle grinder & dragging it out.
PostPosted: Mon Dec 13, 2010 12:13 pm Up
Even easier.
Tell the buyer its out the car & they can come move it themself Wink
PostPosted: Mon Dec 13, 2010 12:14 pm Up
Oh and shell cant be rolled over as the doors & glass is still in it and they're needed. Plus there are bushes all around it.
Mattie-RS
I once lifted a engine into a van with 2 guys,,
not recomended there heavy Laughing
Id put some wood down to make tracks and drag the engine
MrBSI wrote:
Even easier.
I tried that but I had to give a refund as the courrier needs it at the top of the drive as the lorry cant get through the gate.
panason1c
PostPosted: Mon Dec 13, 2010 12:15 pm Up
Get a few friends round to lift the car clear, then lay planks along the gravel drive to form two tracks so that you can drag the engine (on a pallet) along using a tow rope and someones car with a towbar fitted.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
Don't you know anyone with a lorry with a hiab? Just get them to pick the car up. Surely there's someone who lives near you thats delivers things or does bangers.
PostPosted: Mon Dec 13, 2010 12:17 pm Up
I was thinking of something along those lines, but lifting it onto a pallet, thats on a pallet truck on a wooden board. And then rolling the pallet truck via laying down boards.
Just after other ideas incase someone had a better one.
NICKST
Cut the bottom slamp panel so the engine can come straight threw the front of the car. Put engine on wooden board put a hole in wooden board tie a piece of rope threw it and drag down the drive with another car. Just an idea.
PostPosted: Mon Dec 13, 2010 12:18 pm Up
A lorry cant get down the drive due to the gate & cattle grid Sad
Page 1 of 3
