Latest: S2cgm
Overall: 17178
Online Now [1241]:
Visitors: 1240
Today: 112558
Total: 136133881
Forums › The Car › 206 Problems › clutch cable /pedal/linkages heeeeelp :S
PostPosted: Fri Dec 17, 2010 6:48 am Up
can someone please advise me on the following Smile
is the gti 206 cable clutch?
if so will the clutch pedal and cable be the same as that for a 1.4 8v?
also will the gearlinkage from the stick to the subframe bit be the same?
i think the gearlinkages from the subframe bit to the box will be different to that of a 1.4 wont it?
are auto and manual starter motors the same on the tu engine?
will my engine run if i fit a manual box and unplug the gearbox ecu or will it affect the engine one?
reason is im converting my auto 206 to manual after the auto box went bang and trying to work out sourcing the right parts Crying or Very sad
i have found a gearbox off a mate and realise i will need a 1.4 flywheel, clutch and cranksensor can anyone else think of other stuff i need?
sorry for the million questions any help would be greatly apprecaited Smile
thanks
matt
PostPosted: Fri Dec 17, 2010 6:53 am Up
thanks
matt
I can answer that one for sure. No they are toally different in length. The GTi & 2.0 HDi share the same linkages for future reference.
panason1c
PostPosted: Fri Dec 17, 2010 7:07 am Up
Starter motors will be the same.
Dont forget to inform DVLA and your insurance company after the conversion.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
PostPosted: Fri Dec 17, 2010 7:10 am Up
cheers guys Smile
yeah they will both be informed Smile
panason1c
PostPosted: Fri Dec 17, 2010 7:13 am Up
I've got a feeling it's gonna be one of those jobs you wished you never started........... )-:
BMW K1200RS
PostPosted: Fri Dec 17, 2010 7:17 am Up
probably Laughing
im a mechanic by trade and have access to all the ramps and equipment at weekends so that isnt a problem Smile although if a cheap accident damaged/mot failure/blown engine 206 comes up i may just buy that and swap all my bits over but cant find anything for less than a grand near me Crying or Very sad
panason1c
PostPosted: Fri Dec 17, 2010 7:25 am Up
In the early days, a conversion from auto to manual was a fairly straighforward job, but with the intervention of electronically controlled auto-gearbox's and, in some cases its ecu linked to the engine ecu, it is much more a complex conversion with a few 'unknowns' likely to be thrown into the equation.
BMW K1200RS
johnk
PostPosted: Fri Dec 17, 2010 10:23 am Up
is the gti 206 cable clutch? gti has no cable its hydraulic
Uses a different pedal to connect to slave cylinder
They are different
matt
Old info post count 1500
PostPosted: Fri Dec 17, 2010 11:15 am Up
think this could be a no go then Sad best start looking for a cheap replacement after xmas then Sad
thanks for the help anyway guys Smile
