Latest: dreyfalon
Overall: 17121
Online Now [270]:
Visitors: 269
Today: 24126
Total: 97427890
Forums › The Car › 206 Problems › i need help......
i need help......
thompson69
PostPosted: Sat Dec 18, 2010 10:37 am Up
hi iv just tryed 2 in wire up my m3 wing mirrors but i shorted my indicator n im at work at 6pm 2nyt can sme1 tell me wht 2 do 2 sort them
1999 1.6 v8 ripspeed front door speckers, jbl back door speskers, vibe slick 6x9s. gti steering wheel, momo gear knob, debadged, after market bonnet vents, m3 mirrors with leds and info sticker
PostPosted: Sat Dec 18, 2010 10:39 am Up
just blown the fuse the fuse box is under the cover under the steering wheel turn the little slotted clip 90 degrees and it pulls off the handbook will tell you which fuse you have blown and there should be some spares in there unless soemone in the past has used them and not replaced them Smile
thompson69
PostPosted: Sat Dec 18, 2010 10:48 am Up
na still na luck mate
SAB206
PostPosted: Sat Dec 18, 2010 10:53 am Up
If you've shorted the wires, it will be the fuse, you 100% sure?
www.sab-graphics.com
I AM SYDLEXIC!
thompson69
PostPosted: Sat Dec 18, 2010 10:58 am Up
iv changed the fuse the handbook said it was
PostPosted: Sat Dec 18, 2010 10:59 am Up
When you put the other side indicator on does it flash a lot faster than usual?
thompson69
PostPosted: Sat Dec 18, 2010 11:04 am Up
it don't flash but it sounds alot faster
thompson69
PostPosted: Sat Dec 18, 2010 11:14 am Up
sorted thanks alot
