Latest: elelectricistadeMateo
Overall: 17127
Online Now [61]:
Visitors: 60
Today: 74
Total: 100398318
Forums › The Car › 206 Problems › Offside lights out
Offside lights out
Highmac
PostPosted: Fri Dec 24, 2010 2:00 am Up
Both side and dip bulbs on driver's side have apparently failed. Main beam, indicator and rear lights all still work. Since two bulbs have gone at once is it possible it's a wiring problem?
I ask because I've seen the instructions for changing the offside bulbs and they seem even more complicated than the nearside one I spent two hours on recently Shocked Shocked
Also, can anyone recommend a good auto electrician in Coventry, Nuneaton, Hinckley area? because in this weather I'd regard it as an investment..... Rolling Eyes
Neil - 2001 (51) 206 HDi
panason1c
PostPosted: Fri Dec 24, 2010 2:12 am Up
It would be unusual for two bulbs to blow together but the side lamp might have blown previously unknown to you, its more obvious when one of the dip beam lights goes out.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
Highmac
PostPosted: Fri Dec 24, 2010 2:54 am Up
You could be right! My wife's been using it during the snow in preference to her Puma and she's not the sort to drive on sidelights Laughing
PostPosted: Fri Dec 24, 2010 5:54 am Up
2 hours to change a bulb on a 206 Shocked
There one of the most easiest cars to change bulbs on around today.
The most taxing part is un clipping the washer bottle filler tube for the offside, that must take all of about 5 seconds tops Laughing
giveitsomebar
PostPosted: Fri Dec 24, 2010 7:17 am Up
quite common on 206's for when one bulb blows the other will only last a few days / weeks so this could of happened if both have blown it would be easier to remove the grill and take the lights out compleatly took me 10 minutes to do this the other day
PostPosted: Fri Dec 24, 2010 7:21 am Up
What you talking aobut take the light out is easier?
To change the bulb on a 206 is easy you do not have to take the light out no way.
Take washer bottle neck off on drivers side and pasenger side just unclip the backing plate.
No headlght remove needed.
Mattie-RS
PostPosted: Fri Dec 24, 2010 7:33 am Up
Try doing one with ABS in the way then you can have a cry Laughing
PostPosted: Fri Dec 24, 2010 7:37 am Up
Ive never had a problem with mine.
Try doing some newish Renault or big Citroen's then you would be crying Laughing
206 are p**s easy to change the bulbs on.
PostPosted: Fri Dec 24, 2010 7:38 am Up
Still easy and no need to take headlight out. Done it on mine with no problem what so ever.
