Latest: S2cgm
Overall: 17178
Online Now [139]:
Visitors: 137
Bots: 2
Today: 50898
Total: 136838123
Forums › The Car › 206 Problems › screenwash fail
screenwash fail
Rob2859
PostPosted: Fri Dec 24, 2010 1:04 pm Up
The other week I found a whole bottle of wilko screenwash which someone had kindly left me in the carpark. I therefor claimed it and brimmed my bottle.
I went to my car earlier to find blue icicles coming from my bumper to the floor. They seem mostly to be coming from the flat section of the arch lining.
Is it likely that the bottle has split or a pipe has come off?
Can I avoid removing the lining as its a ball ache?
Thanks Very Happy
Antknee
PostPosted: Fri Dec 24, 2010 1:27 pm Up
mine done this, well similar, where the neck and the bottle join isnt watertight on mine! took me a few mins to work out why it was taking so much water to fill up Razz
PostPosted: Fri Dec 24, 2010 1:41 pm Up
just to fill it up to the neck,because when it gets to the neck it will spell it all on the floor,mine do the same
Rob2859
PostPosted: Fri Dec 24, 2010 1:51 pm Up
I brimed it to the neck and didn't use it and when i lookedthe neck was empty. no sign of leakinging from there. Just down off the bumper. it looks like the car is melting.
Bailey
PostPosted: Fri Dec 24, 2010 3:05 pm Up
Exactly what mine does. I've never fixed it just take more trips to the tap.
skard
PostPosted: Fri Dec 24, 2010 3:26 pm Up
has the O ring halfway down snapped? causing it to leak at the joint (about 8 inches down from the top).
i recently had to replace it on the 206 (again).
Rob2859
PostPosted: Fri Dec 24, 2010 6:11 pm Up
do you mean where the pipe removes so you can access the headlight?
skard
PostPosted: Sat Dec 25, 2010 2:41 pm Up
yes
Davo_Pug
PostPosted: Wed Dec 29, 2010 5:46 am Up
It has a separate neck that attaches to the main reervoir of the screen wash as Antknee said it isnt water tight and sometimes needs a wiggle to realign it better....I once thought my car was melting too!!haha
Davo_
brad-morris
PostPosted: Wed Dec 29, 2010 7:31 am Up
Thats carma for you, you shouldn't be stealing Laughing
