Posted: Fri Dec 24, 2010 3:08 pm |
Morning peoples,
Bit of a problem, every time i turn the climate control up to full it eats most of the voltage of my system taking it down from 14.3 to 12 or sometimes 11 volts
I can have it just one fan below the maximum but it doesnt really blow out much and then on full whack it melts your face?
I even put on a merc 110 ah battery on to see if mine was at fault, but no it still managed to drop that too
Any ideas?
Ps the fan squeeks alot to
| Team Impossible Possible
Posted: Fri Dec 24, 2010 3:12 pm |
Might be the fan blower motor bearings seizing and causing the motor to draw too many amps.
| 1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS | |
Posted: Fri Dec 24, 2010 3:13 pm |
What's the problem?
| panason1c wrote: |
| Might be the fan blower motor bearings seizing and causing the motor to draw too many amps. |
I was thinking that, any advice on how to change it?
Posted: Fri Dec 24, 2010 3:16 pm |
| E5GDM wrote: |
| What's the problem? |
It drops the volts to much, problems for people who funny enough like 14.4 volts for ICE
Posted: Fri Dec 24, 2010 3:25 pm |
Might be because you installed climate control yourself and f****d it up!! LOL
| 4.0 V8 S-Type Jaguar
Image removed due to size | |
Posted: Fri Dec 24, 2010 3:39 pm |
would it not be that thing bolted to the heater matrix starting to burn out, help me out guys, whats it called, some one else had a problem with one the other day.
it controls the amount of voltage that goes to the motor to give you the different speeds
| Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k. | |
Posted: Fri Dec 24, 2010 4:54 pm |
| namgaj wrote: |
Might be because you installed climate control yourself and f****d it up!! LOL  |
Posted: Sat Dec 25, 2010 6:12 am |
| addaz wrote: |
| panason1c wrote: |
I was thinking that, any advice on how to change it? |
Take the glove box out & have a look, fans at the top of the dash in the middle.
Posted: Sat Dec 25, 2010 8:05 am |
| Ash wrote: |
| namgaj wrote: |
Yeh probaly
Might aswell check it today, sick of christmas already
Posted: Sat Dec 25, 2010 8:11 am |
Aww come on addaz cheer up lad I'll flash you my moobs if it'l raise a smile
Posted: Sat Dec 25, 2010 8:29 am |
| namgaj wrote: |
Aww come on addaz cheer up lad I'll flash you my moobs if it'l raise a smile  |
Dont think that will make me smile mate, not sure anything will for sometime now
